Category
Top » Fax/I-Fax Inbox » Confidential Fax Inbox » Printing a File in a Confidential Fax Inbox
Category Top
Overview of This Function
Processing Received Files
Memory RX Inbox
Memory RX Inbox
Receiving Files Through Fax or I-Fax
Checking the Detailed Information for/Deleting a File in the Memory RX Inbox
Printing a File in the Memory RX Inbox
Sending a File in the Memory RX Inbox
Divided Data RX Inbox
Checking the Detailed Information for/Deleting a File in a Confidential Fax Inbox
Collapse all|Expand all
Press [Fax/I-Fax Inbox] → [Confidential Fax Inbox].
Select the desired inbox.
Select the file that you want to print → press [Print].
4.
Press [Start Printing].
If you want to automatically delete the selected file after it is printed, press [Delete File After Printing].
You can print stored files only with the same settings as when they were received.
You cannot print multiple files simultaneously. To print multiple files, select and print one file at a time.
