Category
Top » Fax/I-Fax Inbox » Confidential Fax Inbox » Checking the Detailed Information for/Deleting a File in a Confidential Fax Inbox
Category Top
Overview of This Function
Processing Received Files
Memory RX Inbox
Memory RX Inbox
Receiving Files Through Fax or I-Fax
Checking the Detailed Information for/Deleting a File in the Memory RX Inbox
Printing a File in the Memory RX Inbox
Sending a File in the Memory RX Inbox
Divided Data RX Inbox
Printing a File in a Confidential Fax Inbox
Collapse all|Expand all
Checking the Detailed Information for a File
Press [Fax/I-Fax Inbox] → [Confidential Fax Inbox].
Select the desired inbox.
Select a file to check → press [Details].
Deleting a File
Select the file that you want to delete → press [Delete].
You can cancel a selection by selecting the file again.
4.
Press [Yes].
