(Start). The machine automatically feeds the originals to the platen glass and scans them. Two-sided originals can also be automatically turned over and scanned as two-sided documents.
If the original has too many pages to be placed in the feeder all at once, use the Job Build mode on the [Options] screen. For more information, see the following:
Job Build for Copy
Job Build for Scan and Store
Job Build for Scan and Send
Job Build for Fax Settings
If the top edge of the original is not aligned with the back edge of the platen glass (by the arrow in the top left corner), your original may not be scanned correctly, depending on the copy mode that you have set.
You can place the originals either vertically or horizontally. However, the scanning speed for horizontally placed originals is somewhat slower than vertically placed originals. Place originals horizontally when scanning with a Preset Zoom, such as when enlarging an LTR original onto 11" x 17" paper.
Horizontally placed LTR and STMT originals are referred to as LTRR and STMTR.
You must place 11" x 17" and LGL originals horizontally.
