This machine is equipped with an open/close sensor of the feeder/platen cover (see circled area in the above illustration). When placing originals on the platen glass, lift the feeder/platen cover approximately 11 7/8" (300 mm) so that the sensor detaches from the feeder/platen cover. If the sensor does not detach from the feeder/platen cover, the size of the originals may not be detected correctly.
When you are enlarging an LTR or STMT original onto 11" x 17" or LGL paper, place the original horizontally on the platen glass, and align it with the LTRR or STMTR marks.
CAUTION |
Close the feeder/platen cover gently to avoid catching your hands, as this may result in personal injury.
Do not press down hard on the feeder/platen cover when using the platen glass to make copies of thick books. Doing so may damage the platen glass and result in personal injury.
Be aware that the light emitted from the platen glass may be very bright when closing the feeder/platen cover.
If you are placing the original on the platen glass, the machine detects the size of the original after the feeder/platen cover is closed. Be sure to close the feeder/platen cover before copying.
Remove the original from the platen glass when scanning is complete.
![]() If the size of the original is not detected, press
(Start) → follow the instructions on the screen to specify the original size. You can also manually select the paper size. |
The machine automatically detects the size of the following originals: 11" x 17", LGL, LTR, LTRR, and STMT.
