e-ManualTopSite mapHelp
Top » Status Monitor/Cancel » Operations from the Job Log Screen
0UKW-0C4
This section describes the operations that you can perform from the Job Log screen.
You can select a job type from the drop-down list to display only jobs of a specific type in the list.
Operations from the Print Screen
Press [Status Monitor/Cancel].
Press [Print] → [Log].
Select the desired job → select the operation to perform.
You can select the following operations.
[Details]:
Displays detailed information for the selected job. Check the detailed information → press [OK] to return to the Print screen.
[Print List]:
Prints the job log list. Press [Print List] → [Yes] to print the list.
The list can be printed only if LGL or LTR (plain, recycled, thin, or color) is loaded in one of the paper sources that is set to 'On' in [Other] in [Paper Drawer Auto Selection On/Off]. (See "Enabling Paper Drawer Auto Selection.")
