e-ManualTopSite mapHelp
Top » Status Monitor/Cancel » Checking the Status of Consumables and Other Information
0UKW-0C5
You can check the status of consumables, such as detailed paper information and the remaining amount of toner and staples. You can also register/set the paper type to load in a paper drawer.
Press [Status Monitor/Cancel].
Press [Consumables].
To check the details of paper loaded in the machine:
To check other information:
To register/set a paper type:
Select the paper you want to check → press [Details].
You can press  to enlarge the displayed list.
Press [OK].
Check the percentage of memory usage, amount of waste toner, and the remaining amounts of toner and staples.
Press [Reg.].
Select an item to register/set → register/set the paper type.
[Paper Settings]:
Sets the paper type to load by selecting a paper source.
[Paper Type Management Settings]:
Registers a user-defined paper type by entering a name.
For instructions on specifying [Paper Settings], see "Registering the Paper Size and Type for a Paper Source."
For instructions on specifying [Paper Type Management Settings], see "Registering/Editing Custom Paper Types."
Press [OK].
