e-ManualTopSite mapHelp
Top » Maintenance » Replacement Parts » Replacing the Staple Cartridge (Staple Finisher-S1)
0UKW-068
This section describes how to replace the staple case and staple cartridge in the stapler unit.
When the Staple Finisher-S1 is almost out of staples and the staple cartridge must be replaced, a screen prompting you to replace the staple cartridge appears on the touch panel display. Follow the procedure described below to replace the staple cartridge.
The Staple Finisher-S1 is an optional product.
We recommend that you order staple cartridges from your local authorized Canon dealer before your stock runs out.
Use only staple cases intended for use with this machine.
Open the front cover of the finisher.
Grasp the staple case by the green tab and pull the staple case out from the stapler unit.
* Staple Case
Squeeze and lift the empty staple cartridge by its sides marked with arrows to remove it from the staple case.
You can lift the staple cartridge only when no staples are left inside the cartridge.
4.
Insert a new staple cartridge into the staple case.
Use only staple cartridges designed for use with this machine. (See "Consumables.")
Only one staple cartridge can be inserted at a time.
5.
Return the staple case to its original position in the stapler unit.
6.
Close the front cover of the finisher.
CAUTION
When closing the front cover of the finisher, be careful not to get your fingers caught, as this may result in personal injury.
After the cover is closed, the stapler unit may automatically perform a "dry" stapling operation to reposition the staples.
