Clearing a Paper Jam in Paper Drawer 3 or 4 (Optional)
0R9W-0K0
Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
Remove any paper jammed in the upper right cover and lower right cover of the paper drawer.
1. Open the upper right cover and lower right cover of the paper drawer.
2. Remove any paper jammed in the upper right cover of the paper drawer.
3. Remove any paper jammed in the lower right cover of the paper drawer..
4. Close the upper right cover and lower right cover of the paper drawer.
Remove any jammed paper from the paper drawer.
1. Grip the handle of the paper drawer (Paper Drawer 3 or 4), and pull out the paper drawer until it stops.
2. Remove any jammed paper.
Gently push the paper drawer back into the machine.
