Top » Problem Solving » Clearing Paper Jams/Staple Jams » Main Unit » When No Option Is Attached
0R9W-0JC
Open the right cover of the main unit.
Remove any jammed paper from the output tray of the main unit.
Remove any jammed paper from the right side of the main unit.
4.
Remove any jammed paper from the upper part of the fixing unit.
1. Open the upper cover of the fixing unit.
2. Remove any jammed paper from the upper part of the fixing unit.
5.
Remove any jammed paper from the lower part of the fixing unit.
1. Remove any jammed paper from the lower part of the fixing unit.
2. Close the upper cover of the fixing unit.
6.
Lift up the duplexing unit, and remove any jammed paper.
7.
Remove any jammed paper from the area near Paper Drawer 1.
8.
Close the right cover of the main unit.
