Top » Problem Solving » List of Error Messages » Authentication Function
0R9W-0KJ
This section describes the error messages related to the authentication function.
Error Messages related to the Authentication Function
Login failed due to an authentication error in Dept. ID Management. Contact system manager.
The authentication server is not found. Contact the system manager for details.
The authentication server is not running. Contact the system manager for details.
The Active Directory site information is incorrect. Contact the system manager.
Login failed. The account information necessary to log in to the authentication server is invalid. Contact system manager.
Login failed. Anonymous access to the authentication server is not allowed. Contact system manager.
Connection test failed. Check the authentication server settings.
Connection test failed. The account information required to log in to the authentication server is incorrect. Check the user information used to log in to the authentication server.
Connection test failed. Anonymous access to the authentication server is not allowed.
Cause
Department ID Management is enabled with User Authentication set, but a Department ID has not been assigned to the user.
Remedy 1
To enable Department ID Management with User Authentication set, the administrator can assign Department IDs to the users.
Remedy 2
The administrator can disable Department ID Management.
Cause 1
The primary/secondary DNS server settings in the machine are incorrect or not specified.
Remedy
Confirm the DNS server settings of the machine, and specify the correct values.
Cause 2
The DNS server specified in the machine is not started, or the service has been stopped.
Remedy
Check the status of the DNS server.
Cause 3
The host record is not on the DNS server or is incorrect.
Remedy
Check whether the host record is on the DNS server. Also confirm that the forwarding settings are correct.
Cause 1
The Active Directory server is not started.
Remedy
Restart the Active Directory server.
Cause 2
The KDC (Key Distribution Center) service of Active Directory is stopped.
Remedy
Check whether the Active Directory server is operating normally.
Cause
The site settings for Active Directory are incorrect.
Remedy
Check the <Site Access Range:> and <Retrieve Site Information:> settings in <Access Mode within Sites:>.
Cause
The user information that was entered does not match the information registered in the destination LDAP server.
Remedy
Enter the correct information or contact the administrator of the LDAP server.
Cause
Anonymous access is not allowed on the destination LDAP server.
Remedy
Refer to "###Registering/Editing LDAP Server Information" to specify the settings for accessing the LDAP server using authentication information.
Cause
The destination LDAP server is not set correctly.
Remedy
Set the destination LDAP server correctly.
Cause
The administrator information is not set correctly on the destination LDAP server.
Remedy
Set the administrator information correctly on the destination LDAP server.
Cause
Remedy
