When the Booklet Finisher-U1/Staple Finisher-U1 Is Attached
0R9W-0JH
Open the right cover of the main unit.
Remove any jammed paper from the buffer pass.
2. Remove any jammed paper.
3. Close the buffer pass.
Remove any jammed paper from the right side of the main unit.
4.
Remove any jammed paper from the upper part of the fixing unit.
1. Open the upper cover of the fixing unit.
2. Remove any jammed paper from the upper part of the fixing unit.
5.
Remove any jammed paper from the lower part of the fixing unit.
1. Remove any jammed paper from the lower part of the fixing unit.
2. Close the upper cover of the fixing unit.
6.
Remove any jammed paper from the duplexing unit.
1. Lift up the duplexing unit, and remove any jammed paper from the upper part of the duplexing unit.
2. Return the duplexing unit to its original position.
3. Remove any jammed paper from the lower part of the duplexing unit.
7.
Remove any jammed paper from the area near Paper Drawer 1.
8.
Close the right cover of the main unit.
