Take care when handling the optional equipment that is attached to the machine. Copying or printing may be performed while the paper jam is being removed.
Document Jams in the Feeder
Paper Jams in the Multi-Purpose Tray
Paper Jams inside the Right Covers of the Main Unit
Paper Jams in the Paper Drawer
Paper Jams in the Paper Deck
Paper Jams in the Main Unit (Fixing Transport Unit)
Paper Jams in the Staple Finisher-V1/Booklet Finisher-V1
Paper Jams in the Document Insertion / Folding Unit-J1
Paper Jams in the Document Insertion Unit-P1
Paper Jams in the POD Deck Lite-C1/Paper Deck Unit-E1
Paper Jams in the Copy Tray-R2|
When removing the jammed paper, do not turn OFF the machineTurning OFF the machine deletes the data that is being printed. Be especially careful when receiving fax documents.
If paper tearsRemove all the paper fragments to prevent them from becoming jammed.
Do not forcibly remove the jammed document or paper from the machineForcibly removing the paper may damage parts. If you are not able to remove the paper, contact your local authorized Canon dealer.
After clearing all paper jamsTo prevent your clothes or hands from being caught between the rollers, immediately remove your hands from the main unit and optional devices.
Even if you check the paper jam location, paper may not actually be jammed. In such a case, check all locations according to the instructions on the touch panel display.
The touch panel display indicating a paper jam is continuously displayed until the paper jam issue has been rectified completely.
If you press <Close> on the touch panel display indicating a paper jam, operation and setting may continue without immediate correction of the paper jam.
If a paper jam occurs during printing while the stapler is set for operation, do not remove paper in the places other than the locations displayed on the touch panel display. For example, if a paper jam occurs in the main unit, you do not need to remove paper from the finisher where a paper jam has not occurred. If a paper jam in the main unit is cleared, paper inside the finisher will be stapled continuously.
