When the Copy Tray-R2 is attached, follow the procedure in Paper Jams in the Copy Tray-R2 to remove jammed paper.
Turn the green lever to the left.
Pull out the fixing transport unit.
Open the left guide.
Gently pull out the paper on the right side of the fixing unit.
Turn the knob in the direction of the arrow to remove the jammed paper.
Gently pull out the paper on the left side of the fixing unit, and remove the jammed paper.
Remove the jammed paper.
Close the left guide.
Pull down the green knob to open the lower guide.
Close the lower guide.
Push the fixing transport unit back into its original position.
Return the green lever to its original position.
Close the front cover.
