Control panel
, indicators, touch panel display, etc. You can perform all the operations and specify settings from the control panel. Control Panel
Feeder
USB port (Front-right side of the machine)
Right cover of the main unit
Multi-purpose tray
Power switch
Front cover of the main unit
Right cover of the paper drawer
Paper drawer 1
Telephone line jack (LINE 1)
Additional telephone line jack (LINE 2)
Glass cleaning sheet storage box
Motion sensor
Output tray
Toner Code
For more information about the configuration of optional equipment installed on the machine, see Options.
1
Press
2
Select the USB memory device that you want to disconnect and press <Remove>.
3
Disconnect the USB memory device from the USB port and press <OK>.
Make sure to follow the proper procedure when removing the memory media. Failure to do so may cause the memory media or machine to malfunction.
The machine supports FAT32/exFAT format memory media.
Make sure that the memory media is oriented properly when connecting it to the machine. If it is not connected properly, it may cause the memory media or machine to malfunction.
Be sure to check before using memory mediaTo use the memory media, it is necessary that <Memory Media> in <Store Location Display Settings> is set to <On>.
Set <Use Scan Function> and <Use Print Function> to <On>. <Use Scan/Print Function>
When the memory media is not recognized even if it is connected properly, the machine may be set to use the MEAP driver for USB external storage device. Set <Use MEAP Driver for USB Storage Device> to <Off>. <Use MEAP Driver for USB Storage Device>
Unsupported devices and usagesMemory media with security functions
Memory media that does not meet the USB specification
Memory card readers connected via USB
Connecting memory media via an extension cable
Connecting memory media via a USB hub
