<Function Settings>
<Store/Access Files>
<Common Settings>
<Scan and Store Settings>
<Function Settings>
<Common Settings>
after performing the following procedure in advance.|
1
Press <Scan and Store> on the Main Menu. <Main Menu> Screen
2
Press the location to save to and select a mail box.
3
Press <Scan>.
4
Specify the scan settings to register.
<Function Settings>
<Common Settings>
1
2
3
Press <Scan>.
4
<Function Settings>
<Common Settings>
<Access Stored Files Settings>
1
Press <Access Stored Files> on the Main Menu. <Main Menu> Screen
2
Press the location of the file to use and select a mail box.
3
Select a file and press <Print>.
4
Specify the print settings to register.
<Function Settings>
<Common Settings>
1
2
3
4
<Function Settings>
<Common Settings>
<Function Settings>
<Mail Box Settings>
<Function Settings>
<Mail Box Settings>
<Settings for All Mail Boxes>
<Function Settings>
<Mail Box Settings>
<Function Settings>
<Mail Box Settings>
<Box Security Settings>
<Function Settings>
<Advanced Box Settings>
<Function Settings>
<Function Settings>
<Function Settings>
<Function Settings>
<Function Settings>
<Function Settings>
Even if this setting is set to <On>, you can send to the Advanced Space of the machine using <Scan and Send> if you specify the address of the machine on the network (the loopback address). Specify the following IP address and host name for the loopback address.
IPv4: 127.0.0.1
IPv6: 0:0:0:0:0:0:0:1 or ::1
Host name: localhost\
<Function Settings>
<Function Settings>
<Function Settings>
<Function Settings>
<Network Settings>
<Function Settings>
<Network Settings>
<Function Settings>
<Network Settings>
<Function Settings>
<Memory Media Settings>
