Basic Paper Loading Method
This section describes the method for loading paper that is used relatively frequently such as plain paper or recycled paper. Load the paper you usually use into the paper drawer. Use the multi-purpose tray when you temporarily use a size or type of paper that is not loaded in the paper drawer.
Loading Paper in the Paper Drawer
1
Hold the handle of the paper drawer and pull it out until it stops.
2
Adjust the position of the paper guides.
Align the left and front guides with the size indicators for the paper to be loaded by sliding each guide while pressing the top part of that guide.
Slide the guides until they click into place. If the left guide and front guide are not aligned correctly, the paper size will not correctly appear on the touch panel display. It is also necessary to adjust the guides correctly to avoid causing a paper jam, dirty prints, or making the inside of the machine dirty.
Size abbreviations on the paper guides
The abbreviations on the paper guides in the paper drawer indicate paper sizes as follows:
LGL: Legal
LTR: Letter
EXEC: Executive
STMT: Statement
When loading inch series paper
Remove the A4 Feeder Attachments and put them in the dedicated storage space. When loading A/B series paper again, make sure to place the A4 Feeder Attachments in service position.
When you have changed the size series of paper to load in the paper drawer, specify the new size series in <Paper Size Group for Auto Recognition in Drawer>.
<Paper Settings>
3
Prepare paper.
Fan the paper stack well, and tap it on a flat surface to align the edges.
Fan all four sides of the paper stack well.
Make sure that there is enough air between each sheet of paper.
4
Load the paper.
Make sure that the paper size setting of the paper drawer matches the size of the paper to load in the paper drawer.
Do not exceed the load limit line when loading paper
Make sure that the paper stack does not exceed the load limit line. Loading too much paper can cause paper jams.
Paper (excluding envelopes):
Envelopes:
If you use paper with a logo mark, pay attention to the orientation when loading it in the paper source.
Loading Preprinted Paper
When placing envelopes, pay attention to the orientation and the preparations before placing envelopes.
Loading Envelopes
For paper that can be loaded in each paper drawer, see
Specifications.
If there are instructions on the paper package about which side of the paper to load, follow those instructions.
Paper may overlap when it is fed or a paper jam may occur, depending on the cut surface of the paper. Changing the paper orientation and loading it again may reduce the effect of the cut surface.
If paper runs out and printing is stopped, load a new paper stack. Printing restarts after the new paper stack is loaded.
5
Gently insert the paper drawer into the machine.
When changing the paper size and type
When changing the paper size, change the paper size label as necessary.
Loading Paper in the Multi-Purpose Tray
1
Open the multi-purpose tray.
Pull out the tray extension when loading large-sized paper.
2
Adjust the paper guides to match the size of the paper.
3
Prepare paper.
4
Insert the paper into the multi-purpose tray until the paper stops.
Load the paper with the print side face down.
The screen for specifying the paper size and type is displayed when the paper is fully inserted.
Make sure that the paper stack does not exceed the load limit line (
). Loading too much paper can cause paper jams.
5
If <Prioritize Printer Driver Settings for Jobs with MP Tray> is set to <On>, printer driver settings are prioritized when the multi-purpose tray is specified as the paper source for jobs from the printer driver.
A paper jam or other printing problems may occur if the size and type of paper specified in the printer driver do not match those of the actual paper loaded in the multi-purpose tray.
TIPS
Printing on the back side of printed paper (2nd Side of 2-Sided Page)
You can print on the back side of printed paper. Flatten any curls on the printed paper and insert it into the multi-purpose tray, with the side to print face down (previously printed side face up). Then press <2nd Side of 2-Sided Page> on the screen for selecting the paper type.
Use only the paper printed with this machine.
Loading Transparencies
You can load LTR size transparencies in the multi-purpose tray. When loading transparencies, note the following points.
If a multiple feed or paper jam occurs, load only one sheet of transparency at a time.
If you leave transparencies loaded in the multi-purpose tray, the sheets may stick together and cause a multiple sheet feed or a paper jam. When printing is complete, return the remaining transparencies to their original package for storage, avoiding locations subject to high temperatures and humidity.
LINKS
