[Copy Sample] appears only if you set to make multiple copies of your original in [Collate (Page Order)], [Offset], [Staple], [Add Cover], [Insert Sheets], [Booklet], or [Transparency Cover Sheets].
The following restrictions apply when specifying pages:
Make sure to specify page numbers based on the output. Note that the page numbers of the output may be different from those of the original.
If you select [Specified Pages], the Staple, Hole Punch, Fold, Booklet or Trim mode cannot be set.
You cannot change the specified page numbers after the copy sample is output.
You cannot change [All Pages] to [Specified Pages] or vice versa after the copy sample is output.
If you select [All Pages], the machine's counter counts the sample set as a copy.
