Top » Copy » Adjusting Density Manually
08KE-0RK
You can manually adjust the density to the most appropriate level for the original.
Setting Density Before Copying
Press [Copy].
Press [Options] → [Density].
Press or to adjust the density for the original → press [OK] → [Close].
The density becomes lighter as the indicator is moved to the left and darker as the indicator is moved to the right.
Setting Density During Copying
Press or to adjust the density for the original.
You cannot change the density while printing with [Secure Watermark] set.
If you change the density in [Options], adjusting the density during copying may not have any effect on the output.
If you want to adjust the background density, see "Adjusting Background Density."
