Top » Copy » Superimpose Image
Superimpose Image
08KE-0SJ
This mode enables you to superimpose a previously scanned image (image form) registered in the machine's memory on the output.
To use the Superimpose Image mode, the image form must be registered in the machine beforehand. (See "Registering Forms for the Superimpose Image Mode.")
If you use the Superimpose Image mode with the Cascade Copy mode, it is necessary to register the same image form with the same name in both the machine and the cascade copy printer in advance.
If the same image form with the same name is not registered in both machines, the job is canceled.
If multiple image forms with the same name as the image form in the machine are registered in the cascade copy printer, different images may be used for Superimpose Image.
Press [Copy].
Press [Options] → [Superimpose Image].
Press [Set] for the side of the paper you want to superimpose.
<Back Side> can only be selected for a two-sided original.
To specify the same settings as <Front Side> for <Back Side>, press [Same as Front Side].
4.
Select the image form to be superimposed over the original → press [OK].
To print and check a registered image form, press [Check Print] → select the paper size → press [Start Printing].
To check the detailed information for the selected image form, press [Details].
5.
Press [OK] → [Close].
Copy modes other than the Shift or Mirror Image mode can only be used for copying images.
You can register up to 100 image forms. However, this number varies depending on the capacity of the hard disk.
Printing performance may not be optimal, depending on the content of the original and image form.
The moiré effect (a shimmering, wavy pattern) may occur, depending on the content of the original and image form.
The check print is a sample print. The actual printout may vary slightly with the check print.
