e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
System Configuration
Optional Equipment
Sample System Configurations
System Options
Optional Products Required for Each Function
Upright Control Panel-B1
Duplex Color Image Reader Unit-G1
Tab Feeding Attachment Kit-B1
Paper Deck Unit-C1/POD Deck Lite-A1
USB Device Port-A2
Multimedia Reader/Writer-A2
Printer Cover-B1
Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO/Puncher Unit-BS1
Staple Finisher-N1/Booklet Finisher-N1/Puncher Unit-BF1/Inner Booklet Trimmer-A1
Professional Puncher Integration Unit-B1
Document Insertion Unit-K1
Paper Folding Unit-H1
Copy Card Reader-F1
ADF Access Handle
Removable HDD Kit
Setting/Removing the Hard Disk Holder
Software
imageWARE ADVANCE Desktop
imageWARE Enterprise Management Console
imageWARE Publishing Manager
imageWARE Scan Manager DS
Workflow Composer
imageWARE Document Server
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
08KE-03E
If the Tab Feeding Attachment Kit-B1 is attached, you can use the following type of tab paper:
LTR
Parts and Their Functions
The Tab Feeding Attachment Kit-B1 can only be attached to Paper Drawer 3 or 4.
Back to Top
