Top » Optional Products/Software » Paper Deck Unit-C1/POD Deck Lite-A1
08KE-03F
If the Paper Deck Unit-C1 or POD Deck Lite-A1 is attached, it can provide an additional paper source.
Up to 3,500 sheets of paper (20 lb bond (80 g/m2)) can be loaded into the Paper Deck Unit-C1 or POD Deck Lite-A1.
If the machine is in the Sleep mode (the touch panel is not displayed, and only (Energy Saver) is lit), you may be unable to open the Paper Deck Unit-C1 or POD Deck Lite-A1. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the Paper Deck Unit-C1 or POD Deck Lite-A1.
The following paper sizes can be loaded into the Paper Deck Unit-C1 or POD Deck Lite-A1:
Paper Deck Unit-C1:
LTR
POD Deck Lite-A1:
13" x 19", 12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, LTR, and LTRR
The paper size of the Paper Deck Unit-C1 is fixed to LTR. For instructions on changing the paper size that can be loaded in the Paper Deck Unit-C1, contact your local authorized Canon dealer.
Parts and Their Functions
Paper Deck Unit-C1
POD Deck Lite-A1
Release Button
Press to move the Paper Deck Unit-C1 or POD Deck Lite-A1 away from the main unit when you want to detach either of them from the machine.
Open Button
Press to open the Paper Deck Unit-C1 or POD Deck Lite-A1 when you need to load paper or check for a paper jam.
Paper Deck
Up to 3,500 sheets of paper (20 lb bond (80 g/m2)) can be loaded.
4.
Paper Supply Indicator
Enables you to check the amount of paper remaining in the Paper Deck Unit-C1 or POD Deck Lite-A1.
