Top » Optional Products/Software » System Configuration » Optional Equipment
Optional Equipment
08KE-036
When the Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO and Upright Control Panel-B1 is attached
Booklet Trimmer-D1
If the Booklet Trimmer-D1 is attached to the Booklet Finisher-Q1 PRO, the fore edge of saddle stitched copies can be trimmed for neat output. For more information on the Booklet Trimmer-D1, see the instruction manual of the Booklet Trimmer-D1.
Staple-P1
The Staple-P1 can be attached to the Booklet Finisher-Q1 PRO for saddle stitching.
The Booklet Finisher-Q1 PRO is equipped with the following features: Collate, Group, Staple (Corner, Double, Saddle Stitch), and Saddle Fold.
4.
Paper Folding Unit-H1
If the Paper Folding Unit-H1 is attached to the Staple Finisher-Q1 PRO or Staple Finisher-Q1 PRO, the paper can be folded in 5 different ways (Z-Fold, Half Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold).
5.
Professional Puncher Integration Unit-B1
The Professional Puncher Integration Unit-B1 reverses the paper punched by the Professional Puncher-C1 to prevent a paper jam.
6.
The Professional Puncher-C1 punches several types of holes. For more information on the Professional Puncher-C1, see the instruction manual of the Professional Puncher-C1.
7.
Document Insertion Unit-K1
If the Document Insertion Unit-K1 is attached, a different type of paper from the body of the document can be inserted for a cover or insert.
8.
Duplex Color Image Reader Unit-G1
You can scan documents such as books, thick originals, thin originals, and transparencies on the platen glass of the Duplex Color Image Reader Unit-G1. A single original can be sent from documents gathered in the feeder attached to the Duplex Color Image Reader Unit-G1.
9.
Upright Control Panel-B1 (standard-equipped for imageRUNNER ADVANCE 8205/8295)
The large size touch panel display enables you to operate the machine more efficiently. You can also adjust the position and angle of the control panel to enable you to see the touch panel display more clearly.
10.
POD Deck Lite-A1
If the POD Deck Lite-A1 is attached, it can provide an additional paper source. The POD Deck Lite-A1 holds up to 3,500 sheets of paper (20 lb bond (80 g/m2)).
11.
Copy Card Reader-F1
The Copy Card Reader-F1 enables Department ID Management to be performed through the use of cards.
12.
Utility Tray-A2
The Utility Tray-A2 provides space for placing originals.
13.
Paper Deck Unit-C1
If the Paper Deck Unit-C1 is attached, it can provide an additional paper source. The Paper Deck Unit-C1 holds up to 3,500 sheets of paper (20 lb bond (80 g/m2)).
14.
Printer Cover-B1
Instead of the Duplex Color Image Reader Unit-G1, you can attach the Printer Cover-B1.
15.
Puncher Unit-BS1
The Puncher Unit-BS1 is equipped with the Hole Punch mode. The Puncher Unit-BS1 can be attached only if the Staple Finisher-Q1 PRO or Booklet Finisher-Q1 PRO is attached.
16.
Staple-N1
The Staple-N1 can be attached to the Staple Finisher-Q1 PRO or Booklet Finisher-Q1 PRO for stapling (Corner/Double).
17.
The Staple Finisher-Q1 PRO is equipped with the following features: Collate, Group, Offset, and Staple (Corner and Double).
18.
Tab Feeding Attachment Kit-B1
The Tab Feeding Attachment Kit-B1 can only be attached to Paper Drawer 3 or 4, and holds only tab papers.
When the Staple Finisher-N1/Booklet Finisher-N1 and Upright Control Panel-B1 is attached
Inner Booklet Trimmer-A1
If the Inner Booklet Trimmer-A1 is attached to the Booklet Finisher-N1, the Trim mode can be used to trim the edges of the booklet.
Staple-P1
The Staple-P1 can be attached to the Booklet Finisher-N1 for saddle stitching.
Booklet Finisher-N1
The Booklet Finisher-N1 is equipped with the following features: Collate, Group, Offset, Staple (Corner/Double/Saddle Stitch), and Saddle Fold.
4.
If the Paper Folding Unit-H1 is attached to the Staple Finisher-N1 or Booklet Finisher-N1, the paper can be folded in 5 different ways (Z-Fold, Half Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold).
5.
6.
7.
8.
9.
10.
POD Deck Lite-A1
11.
Copy Card Reader-F1
12.
Utility Tray-A2
13.
Paper Deck Unit-C1
14.
Printer Cover-B1
15.
Puncher Unit-BF1
The Puncher Unit-BF1 is equipped with the Hole Punch mode. The Puncher Unit-BF1 can be attached only if the Staple Finisher-N1 or Booklet Finisher-N1 is attached.
16.
Staple-N1
The Staple-N1 can be attached to the Staple Finisher-N1 or Booklet Finisher-N1 for stapling (Corner/Double).
17.
Staple Finisher-N1
The Staple Finisher-N1 is equipped with the following features: Collate, Group, Offset, and Staple (Corner/Double).
18.
