Category
Top » Fax » Sending/Receiving a Fax » When Problems Occur » Trouble in Other Situations
Category Top
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Collapse all|Expand all
Transmissions are slow.
Are documents being sent at a high resolution?
It is recommended that you send documents containing text only in a lower resolution.
Fax transmissions are slow.
Is [ECM TX] or [ECM RX] set to 'On'?
Check the settings for [ECM TX] and [ECM RX]. (See "Enabling ECM Transmission.")
Was the original type set to [Text/Photo] when sending the document?
If the original does not contain any photos, select [Text] from [Original Type]. (See "Setting Original Type.")
Cannot use fax information services.
If your machine is connected to a rotary pulse line, is it set for tone dialing?
Set the machine for tone dialing to use fax information services. (See "Fax Information Services.")
Did you receive an instruction from the sender to set the machine to receive?
Press [Start RX]. (See "Fax Information Services.")
Documents cannot be sent overseas (error code #018).
Is a pause inserted in the fax number?
Insert a pause after the country code, or after the fax number of the recipient, and then dial the number again. (See "Entering a New Fax Number.")
Change the Long Distance setting on the Option screen if you are sending documents to destinations stored in the Address Book. (See "Checking/Editing/Deleting a Stored Address.")
Calls are not connected, or an incorrect number is dialed.
Did you hear the dial tone before entering the fax number?
Make sure that you hear the dial tone before entering the fax number. If you enter the fax number before hearing the dial tone, the call may not be connected, or an incorrect number may be dialed.
