Be sure to correctly set the paper type. If the type of paper is not set correctly, it may adversely affect image quality. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
The Finishing modes cannot be set if free size, custom size, transparencies, tracing paper, or labels is selected.
If you set the Staple, Hole Punch, or Z-Fold mode, the side of the paper which is printed on will always be output face down.
The paper used for the cover page must be the same size as that which is used for the main document.
If you are loading preprinted paper to use as the cover page into the document insertion unit, you must load the paper face up.
Only 16 lb bond to 80 lb cover (60 to 220 g/m2) paper can be used for the main document.
Only more than the paper weight of main document, and 16 lb bond to 140 lb index (60 to 256 g/m2) or more can be used for the cover paper.
The [Saddle Stitch] mode can be set only if 2-Sided Copying is set.
The accuracy of folds created in the Saddle Stitch mode may vary, depending on the paper type and the number of sheets.
To use the Saddle Stitch mode, the original must already be in booklet form, as shown in the illustration above. (See "Booklet Mode.")
If you specify the Z-Fold mode with the Staple mode, and the number of sheets that are Z-folded exceeds 10, the prints will be collated, but not stapled.
If you want the printed side to be folded inside, select [Up (Reverse Order)] for [Face Up/Face Down].
[Saddle Fold] can only be set when two-sided copying is set.
The paper is saddle folded one sheet at a time, and then output.
You can only set [Rotate 90 Degrees] in the following cases:
If you select the available paper size manually
If the paper size compatible with Rotate 90 Degrees is loaded in both the horizontal and vertical directions
If [Paper Drawer Auto Selection On/Off] for the selected paper source is set to 'On' (See "Enabling Paper Drawer Auto Selection.")
If there is no paper which can be rotated, the output is collated.
Optional Unit
Collate
(Page Order) |
Group
(Same Pages) |
Offset
Rotate 90 Degrees
Staple
Hole Punch
Fold
Trim
Face Up/Face Down
Corner
Double
Saddle Stitch
Saddle Fold
Z-Fold,
C-Fold |
None
Copy Tray-Q1
Staple Finisher-P1
Staple Finisher-P1 and Puncher
Staple Finisher-P1 / Document Insertion/Folding Unit-H1
Booklet Finisher-P1
Booklet Finisher-P1 and Puncher
Booklet Finisher-P1 / Document Insertion/Folding Unit-H1
Paper Size
Corner
Double
Saddle Stitch*
12" x 18"
16 sheets
12 5/8" x 17 11/16"
11" x 17"
30 sheets
30 sheets
16 sheets
LGL
30 sheets
30 sheets
16 sheets
LTRR
30 sheets
30 sheets
16 sheets
LTR
50 sheets
50 sheets
EXEC
50 sheets
50 sheets
STMTR
STMT
For information on the original orientation and paper orientation when performing stapling, see "Relationship Between the Original Orientation and Paper Orientation."
For information on optional products, see the following:
If [Finishing] is not set, sheets are output in the same way as when [Group (Same Pages)] is set.
If [Auto Collate] is set to 'On', the Collate or Offset Collate mode is automatically set when you place your originals in the feeder. (See "Enabling Auto Collating.")
You can display the detailed information of the selected paper by pressing
