Paper Feeding Tray of the Document Insertion/Folding Unit-H1/Document Insertion Unit-L1
You can load paper you want to use as a cover, sheet insertion, or job separator, etc.
Top Cover of the Document Insertion/Folding Unit-H1/Document Insertion Unit-L1
Open this cover to remove jammed paper. (See "Document Insertion/Folding Unit-H1/Document Insertion Unit-L1 (Optional).")
Front Cover of the Document Insertion/Folding Unit-H1/Document Insertion Unit-L1
4.
Exit Slot of the Document Insertion/Folding Unit-H1
C-folded prints are output to this exit slot.
If LTRR is Z-folded, please note that the Auto Orientation Setting differs depending on the orientation of the original.
*1 If Auto Orientation is set to 'Off', part of the image may cut off.
*2 If Auto Orientation is set to 'On', LTRR is selected automatically. However, if the Merge Job Blocks is set, LTRR is not selected automatically.
If 11" x 17" paper and LTR paper are loaded together, only 11" x 17" paper is Z-folded. Even if you set the original in LTR orientation and set Auto Orientation Setting to 'On', LTRR paper is not selected if you set [Different Size Originals].
The Z-folded areas are as shown in the illustration below.
Platen Glass ![]() Feeder ![]() The finishing modes available when the Z-Fold mode is set differ according to the paper size, and are as follows.
LGL, LTRR: No Collating
11" x 17": No Collating, Collate, Offset Collate, Group, Offset Group, Staple, Hole Punch
If paper that has been Z-folded is included in the output, the sheets may not be aligned when output.
The C-folded areas are as shown in the illustration below.
Platen Glass
![]() Feeder
Paper which has been rolled or curled must be straightened out before placing it into the document insertion unit.
Do not place the following types of paper into the document insertion unit. Doing so may cause a paper jam.
Insertion sheets with tears
Severely curled or wrinkled paper
Clipped or stapled insertion sheets
Transparencies or other highly transparent insertion sheets
Tracing paper
Pre-punched paper
Labels
How to Place the Cover Sheet/Original
Staple Settings/Output
Result |
Feeder
Platen Glass
Corner: Upper Left
Double: Left
![]() LTR
Corner: Lower Left
Double: Left
![]() 11" x 17" 11" x 17"
LGL
Corner: Upper Right
Double: Right
LGL
Corner: Lower Left
Double: Left ![]() LTR
Corner: Upper Right
Double: Right
![]() LTR
Corner: Upper Left
Double: Left
LGL |
Corner: Upper Right
Double: Right
![]() LTR
Corner: Upper Left
![]() 11" x 17", LGL
Corner: Lower Right
Corner: Upper Left
![]() LTR
Corner: Lower Right
![]() LTR
Corner: Upper Right
Double: Right
LGL |
Saddle Stitch
For instructions on loading paper into the Document Insertion/Folding Unit-H1 or Document Insertion Unit-L1, see "Loading Paper into the Document Insertion/Folding Unit-H1/Document Insertion Unit-L1 (Optional)."
