Function
Optional Product Required
Notes
Feeding Tab Paper from Paper Source
Tab Feeding Attachment Kit-B1
Printer Cover-B1 and Duplex Color Image Reader Unit-G1 cannot be attached at the same time.
Change Control Panel Type
Upright Control Panel-B1
Upright Control Panel-B1 and Control Panel (Flat) (standard-equipped for this machine) cannot be attached at the same time.
Scanning Originals/Auto Document Feed/Job Build
Adding High Capacity Feeding Area
Paper Deck Unit-A1 or Paper Deck Unit-D1
Paper Deck Unit-A1 and Paper Deck Unit-D1 cannot be attached at the same time.
Collate/Group/Rotate 90 Degrees/Additional Output Tray on the Right Side of the Machine
Copy Tray-Q1
Copy Tray-Q1 and Staple Finisher-P1 or Booklet Finisher-P1 cannot be attached at the same time.
Collate/Group/Offset
Saddle Fold
Booklet Finisher-P1
Corner Staple/Double Staple
Staple-J1
Saddle Stitch Booklet
Staple Cartridge-D2 or Staple Cartridge-D3
Booklet Finisher-P1
Hole Punch
External 2/3 Hole Puncher-A1
Additional Paper Type for Covers/Paper Insertion
Document Insertion/Folding Unit-H1 or Document Insertion Unit-L1
Copy Tray-Q1 and Staple Finisher-P1, or Booklet Finisher-P1 cannot be attached at the same time.
Document Insertion Unit-L1 and Document Insertion/Folding Unit-H1 cannot be attached at the same time.
Z-Fold/C-Fold/Additional Paper Type for Covers/Paper Insertion
Space for Placing Originals
Utility Tray-A2
Closing the Feeder
ADF Access Handle
Department ID Management Using Card
Copy Card Reader-F1
Additional USB Port
USB Device Port-A2
Multimedia Reader/Writer
Multimedia Reader/Writer-A2
USB Device Port-A2
Machine Function
Required
Limitations
PCL Print
PCL Printer Kit
PS Print
PS Printer Kit
imagePASS
The imagePASS cannot be used with the print function of the machine or the PS Printer Kit.
Direct Print (PDF)/Printing PDF files stored in memory media, the Advanced Box, or the Advanced Box of another imageRUNNER ADVANCE machine on the network.
PS Printer Kit or Direct Print Kit (for PDF/XPS)
If the PS Printer Kit is used, the Direct Print Kit (for PDF/XPS) is not required.
Direct Print (XPS)
Barcode Print
Barcode Printing Kit
PCL Printer Kit
Fax Function
Memory Sending/Register Sender Name/Use Authentication User Name as Sender Name/Confirm Entered Fax Numbers/Subaddress Sending/Fax TX Report/Fax Activity Report/Fax User Data List/Set Line/Tone/Pause/PIN Code Access
Super G3 FAX Board or Remote Fax Kit
To use these functions on the Remote Fax Kit, the imageRUNNER ADVANCE series (Remote Fax server machine) with Super G3 FAX Board must correctly be connected with this machine.
To use [Select Line] , you must have more than one telephone line.
Fax Function
Direct Sending/Register Unit Telephone Number/Register Unit Name/Volume Settings/Allow Fax Driver TX/ECM TX/Auto Redial/Send Start Speed/Memory Receiving/ECM RX/Subaddress Receiving/Receive Start Speed/Receive Password/Forwarding Settings/Fax RX Report/Confidential Fax Inbox RX Report/Select Line Type/Onhook/Manual Sending/Check Dial Tone Before Sending/Pause Time
Super G3 FAX Board
Functions Related to Remote Fax
(Settings as a server machine)
Remote Fax Settings
Super G3 FAX Board
Remote Fax Function
(Settings as a client machine)
Send Remote Fax/Send Remote Fax Settings
Remote Fax Kit
To use these functions, the machine with Super G3 FAX Board must correctly be connected with this machine.
Fax Function with 2 Lines
Super G3 2nd Line Fax Board
Super G3 FAX Board
The following functions are only available with Line 1 (the standard line):
Fax/Tel Auto Switch
Remote RX
Audible Tones
On-Hook
Fax Function with 3 to 4 Lines
Super G3 3rd/4th Line Fax Board
Super G3 FAX Board and Super G3 2nd Line Fax Board
Trace & Smooth PDF
Universal Send Advanced Feature Set
Reader Extensions PDF
Encrypted PDF
Universal Send Security Feature Set
Device Signature PDF/XPS
User Signature PDF/XPS
Universal Send Digital User Signature Kit
Secure Watermark
Secure Watermark
HDD Data Mirroring
HDD Mirroring Kit
2.5inch/160GB HDD or 2.5inch/1TB HDD
The HDD Mirroring Kit cannot be used with the HDD Data Encryption & Mirroring Kit.
The HDD Data Encryption & Mirroring Kit cannot be used with the HDD Mirroring Kit.
Removable HDD Management
Removable HDD Kit
Restricting Document Duplication/Track Users
Document Scan Lock Kit
Viewing Web Pages
Web Access Software
Printing Web Pages (PDF)/Storing files in Mail Box (PDF)
Encrypted Secure Printing
Encrypted Secure Print Software
The Encrypted Secure Print Software cannot be used with the imagePASS.
Registering Combinations of Functions
Workflow Composer
Voice Guidance
Voice Guidance Kit/Voice Operation Kit
Voice Operation
Voice Operation Kit
The Voice Operation Kit cannot be used with the SSO-H user authentication function.
Operation of the Machine from Computer
Remote Operator's Software Kit
The Super G3 FAX Board and Remote Fax Kit cannot be used at the same time.
To scan originals using the feeder or platen glass, the Duplex Color Image Reader Unit-G1 is necessary.
