If you are copying onto the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray, Paper Deck Unit-A1 or Paper Deck Unit-D1: Load the side to copy on face down.
Other Settings
Example of Stapling Position
Corner: Top Right
Double: Right ![]() LTR
Corner: Top Right
Double: Top ![]() 11" x 17", LGL, LTRR
Corner: Top Right
![]() LTR, LTRR
Corner: Top Right
Double: Right ![]() 11" x 17", LGL, LTRR
Preprinted paper
Loading location:
Paper Drawer 1 and 2 Preprinted paper: Face down |
Loading location:
Paper Drawer 3 and 4 Preprinted paper: Face down |
Loading location:
Paper Deck Unit-A1 Preprinted paper: Face up |
Loading location:
Multi-purpose tray Paper Deck Unit-D1 Preprinted paper: Face up |
Original
Loading location: Platen glass
Original: Face down |
Stapling setting
Corner: Top Right
Double: Right |
Corner: Bottom Right
Double: Right |
Corner: Top Right
Corner: Top Right
Double: Right |
Loading location: Feeder
Original: Face up |
Stapling setting
Corner: Top Right
Double: Right |
Double: Right |
Corner: Top Right
Corner: Top Right
Double: Right |
Auto Rotation Setting
Both ON and OFF available
Both ON and OFF available (ON when loaded vertically in the paper drawer 3 and 4/Multi-purpose tray/Paper Deck Unit-D1)
Other Settings
Corner: Top Left
Double: Left
![]() LTR
Corner: Top Left
Double: Top
Corner: Top Left
![]() LTR, LTRR
Corner: Top Left
Double: Left
Preprinted paper
Loading location:
Loading location:
Loading location:
Loading location:
Original
Stapling setting
Corner: Top Left
Double: Left |
Corner: Top Right
Double: Right |
Corner: Top Left
Corner: Top Left
Double: Left |
Original: Face up |
Stapling setting
Corner: Top Left
Double: Left |
Corner: Top Right
Double: Right |
Corner: Top Left
Corner: Top Left
Double: Left |
Other Settings
Example Output
![]() LTR
![]() LTR, LTRR
Preprinted paper
Loading location:
Loading location:
Loading location:
Paper Deck Unit-A1Paper Deck Unit-A1 Preprinted paper: Face up |
Loading location:
Original
Original: Face down
Original: Face up
Function
Functions that Cannot Be Used in Combination
Preset Zoom
Zoom by Percentage*1, XY Ratio*1, Auto Ratio/Auto XY Ratio*1, Set by Length*1, Scan Lock Information, Tracking Information, N on 1*2, Booklet*2, Booklet: Saddle Stitch*2, Booklet: Add Cover (Printed/Leave Blank)*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2
Zoom by Percentage
Preset Zoom*1, XY Ratio*1, Auto Ratio/Auto XY Ratio*1, Set by Length*1, Scan Lock Information, Tracking Information, N on 1*2, Booklet*2, Booklet: Saddle Stitch*2, Booklet: Add Cover (Printed/Leave Blank)*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2
XY Ratio
Preset Zoom*1, Zoom by Percentage*1, Auto Ratio/Auto XY Ratio*1, Set by Length*1, Scan Lock Information, Tracking Information, N on 1*2, Booklet*2, Booklet: Saddle Stitch*2, Booklet: Add Cover (Printed/Leave Blank)*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2
Preset Zoom*1, Zoom by Percentage*1, XY Ratio*1, Set by Length*1, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Scan Lock Information, Tracking Information, Tab, Repeat Images, Print on Tab
Set by Length
Preset Zoom*1, Zoom by Percentage*1, XY Ratio*1, Auto Ratio/Auto XY Ratio*1, Scan Lock Information, Tracking Information, N on 1*2, Tab, Booklet*2, Booklet: Saddle Stitch*2, Booklet: Add Cover (Printed/Leave Blank)*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2, Print on Tab
Fit to Page
Multi-Purpose Tray: Free Size, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Tab, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Mirror Image, Print on Tab, Page Numbering, Copy Set Numbering, Print Date, Watermark
Printed Image
Photo Printout*1, Text*1, Text/Photo*1
Photo Printout
Printed Image*1, Text*1, Text/Photo*1
Text
Printed Image*1, Photo Printout*1, Text/Photo*1
Text/Photo
Printed Image*1, Photo Printout*1, Text*1
Function
Auto Select Paper
Auto Ratio/Auto XY Ratio, Auto Select Paper/Auto Orientation*1, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Add Cover (Print/Leave Blank), C-Fold, N on 1, Front Cover, Sheets/Chapter Pages, Tab, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Print on Tab
Auto Ratio/Auto XY Ratio, Auto Select Paper*1, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Add Cover (Print/Leave Blank), C-Fold, N on 1, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Different Size Originals, Repeat Images, Print on Tab
Paper Drawer Auto Selection On/Off
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Transparency Cover Sheets
Multi-Purpose Tray
Transparency Cover Sheets, Share Copy with Local Device
Auto Ratio/Auto XY Ratio, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Paper Drawer Auto Selection On/Off, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Z-Fold, C-Fold, Offset, Hole Punch, 1-Sided
Auto Select Paper, Auto Select Paper/Auto Orientation, Paper Drawer Auto Selection On/Off, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Z-Fold, C-Fold, Hole Punch, Book
Function
Collate
Multi-Purpose Tray: Free Size, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Add Cover (Print/Leave Blank)*1, Offset*1, Transparency Cover Sheets, Booklet*3, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank)*3, Booklet: Divided Booklet*3, Booklet: Creep Correction*3
Group
Multi-Purpose Tray: Free Size, Collate*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Add Cover (Print/Leave Blank)*1, Offset*1, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Copy Sample, Print on Tab, Copy Set Numbering, Merge Job Blocks, Secure Watermark*2
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Collate*1, Group*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Add Cover (Print/Leave Blank)*1, C-Fold, Offset*1, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Share Copy with Local Device, Print on Tab, Merge Job Blocks
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Add Cover (Print/Leave Blank)*1, C-Fold, Offset*1, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Copy Sample, Share Copy with Local Device, Print on Tab, Copy Set Numbering, Merge Job Blocks, Secure Watermark*2
Offset Collate
Multi-Purpose Tray: Free Size, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Group*1, Staple*1, Saddle Stitch*1, Add Cover (Print/Leave Blank)*1, C-Fold, Offset*1, Transparency Cover Sheets, Booklet*3, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank)*3, Booklet: Divided Booklet*3, Booklet: Creep Correction*3
Offset Group
Multi-Purpose Tray: Free Size, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Saddle Stitch*1, Add Cover (Print/Leave Blank)*1, C-Fold, Offset*1, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Copy Sample, Print on Tab, Copy Set Numbering, Merge Job Blocks, Secure Watermark*2
Staple
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Saddle Stitch*1, Add Cover (Print/Leave Blank)*1, C-Fold, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction
Saddle Stitch
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Z-Fold, C-Fold, Offset*1, Hole Punch, 2-Sided
Function
Z-Fold
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Add Cover (Print/Leave Blank), C-Fold, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction
C-Fold
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Z-Fold, Offset, Hole Punch, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing)
Offset
Multi-Purpose Tray: Free Size, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Saddle Stitch*1, Add Cover (Print/Leave Blank)*1, C-Fold, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Creep Correction
Hole Punch
Multi-Purpose Tray: Free Size, Saddle Stitch, Add Cover (Print/Leave Blank), C-Fold, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction
Function
Interrupt Copy
Reserve Copy
Preset Zoom, Zoom by Percentage, XY Ratio, Auto Ratio/Auto XY Ratio, Set by Length, Tracking Information, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Share Copy with Local Device, Sharpness, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Secure Watermark
Preset Zoom, Zoom by Percentage, XY Ratio, Auto Ratio/Auto XY Ratio, Set by Length, Scan Lock Information, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Share Copy with Local Device, Sharpness, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Secure Watermark
1-Sided
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, 2-Sided
2-Sided
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, 1-Sided
2-Sided
Saddle Stitch, Add Cover (Print/Leave Blank), 1-Sided
Book
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Add Cover (Print/Leave Blank), 1-Sided
Book
N on 1
Preset Zoom*2, Zoom by Percentage*2, XY Ratio*2, Set by Length*2, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Add Cover (Print/Leave Blank), Scan Lock Information, Tracking Information, 1-Sided
Fit to Page, N on 1, Erase Book Frame*1, Erase Binding*1, Tab, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Mirror Image, Print on Tab, Page Numbering, Copy Set Numbering, Print Date, Watermark
Erase Book Frame
Fit to Page, N on 1, Erase Original Frame*1, Erase Binding*1, Tab, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Mirror Image, Print on Tab, Page Numbering, Copy Set Numbering, Print Date, Watermark
Erase Binding
Fit to Page, Book
Function
Gutter
Shift: By Position
Multi-Purpose Tray: Free Size, N on 1*1, Shift: By Numeric Keys*1, Tab, Different Size Originals, Repeat Images, Mirror Image, Print on Tab
Multi-Purpose Tray: Free Size, N on 1, Shift: By Position*1, Tab, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Different Size Originals, Share Copy with Local Device, Repeat Images, Mirror Image, Print on Tab, Page Numbering, Copy Set Numbering, Print Date, Watermark
Front Cover
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Add Cover (Print/Leave Blank), C-Fold, Book
Tab
Auto Ratio/Auto XY Ratio, Set by Length, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Add Cover (Print/Leave Blank), C-Fold, Book
Auto Select Paper/Auto Orientation, Paper Drawer Auto Selection On/Off, Multi-Purpose Tray, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Z-Fold, C-Fold, Offset, Hole Punch, Scan Lock Information, Tracking Information, 1-Sided
Function
Booklet
Preset Zoom*2, Zoom by Percentage*2, XY Ratio*2, Set by Length*2, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*3, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate*3, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Z-Fold, C-Fold, Offset, Hole Punch, Scan Lock Information, Tracking Information, 1-Sided
Preset Zoom*2, Zoom by Percentage*2, XY Ratio*2, Set by Length*2, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Z-Fold, C-Fold, Offset, Hole Punch, Scan Lock Information, Tracking Information, 1-Sided
Preset Zoom*2, Zoom by Percentage*2, XY Ratio*2, Set by Length*2, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*3, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate*3, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Z-Fold, C-Fold, Hole Punch, Scan Lock Information, Tracking Information, 1-Sided
Function
Copy Sample
Group, Rotate 90 Degrees: Group, Offset Group, Interrupt Copy, Reserve Copy, Share Copy with Local Device, Store in Mail Box
Auto Select Paper/Auto Orientation, Book
Multi-Purpose Tray, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Add Cover (Print/Leave Blank), Interrupt Copy, Reserve Copy, Scan Lock Information, Tracking Information, Shift: By Numeric Keys, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Copy Sample, Mirror Image, Print & Check, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing), Secure Watermark
Sharpness
Scan Lock Information, Tracking Information, Secure Watermark
Superimpose Image
Multi-Purpose Tray: Free Size, Saddle Stitch, Add Cover (Print/Leave Blank), Scan Lock Information, Tracking Information, N on 1, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Repeat Images, Print & Check, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing), Secure Watermark
Nega/Posi
Scan Lock Information, Tracking Information, Merge Job Blocks, Secure Watermark
Repeat Images
Auto Ratio/Auto XY Ratio, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Scan Lock Information, Tracking Information, Book
Mirror Image
Fit to Page, Scan Lock Information, Tracking Information, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift: By Position, Shift: By Numeric Keys, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Share Copy with Local Device, Repeat Images, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing), Secure Watermark
Function
Print on Tab
Auto Ratio/Auto XY Ratio, Set by Length, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Add Cover (Print/Leave Blank), C-Fold, 1-Sided
Print & Check
2-Sided
Page Numbering
Fit to Page, Multi-Purpose Tray: Free Size, Saddle Stitch, Add Cover (Print/Leave Blank), Scan Lock Information, Tracking Information, Erase Original Frame, Erase Book Frame, Erase Binding, Shift: By Numeric Keys, Transparency Cover Sheets, Superimpose Image, Mirror Image, Print on Tab, Secure Watermark
Copy Set Numbering
Fit to Page, Multi-Purpose Tray: Free Size, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Add Cover (Print/Leave Blank), Scan Lock Information, Tracking Information, Erase Original Frame, Erase Book Frame, Erase Binding, Shift: By Numeric Keys, Transparency Cover Sheets, Superimpose Image, Mirror Image, Print on Tab, Secure Watermark
Print Date
Fit to Page, Multi-Purpose Tray: Free Size, Saddle Stitch, Add Cover (Print/Leave Blank), Scan Lock Information, Tracking Information, Erase Original Frame, Erase Book Frame, Erase Binding, Shift: By Numeric Keys, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Mirror Image, Secure Watermark
Watermark
Fit to Page, Multi-Purpose Tray: Free Size, Saddle Stitch, Add Cover (Print/Leave Blank), Scan Lock Information, Tracking Information, Erase Original Frame, Erase Book Frame, Erase Binding, Shift: By Numeric Keys, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Mirror Image, Print on Tab, Secure Watermark
Merge Job Blocks
Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Add Cover (Print/Leave Blank), C-Fold, Front Cover, Sheets/Chapter Pages, Tab, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Share Copy with Local Device, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Print on Tab, Print & Check
Store in Mail Box
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, C-Fold, Copy Sample, Share Copy with Local Device, Superimpose Image, Mirror Image, Print & Check
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, C-Fold, Share Copy with Local Device, Superimpose Image, Mirror Image
Secure Watermark
Multi-Purpose Tray: Free Size, Group*1, Rotate 90 Degrees: Group*1, Offset Group*1, Scan Lock Information, Tracking Information, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Share Copy with Local Device, Sharpness, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark
