Disabling HTTP Communication
HTTP is used for communications over the network, such as when you access the machine via the Remote UI. If you are using a USB connection or are otherwise not using HTTP, you can disable HTTP to block malicious third-party intrusions via the unused HTTP port.
Disabling HTTP disables some of the network capabilities, such as the Remote UI or WSD printing.
1
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_menu18.gif)
2
Use
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_up18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_down18.gif)
to select <Network Settings>, and press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif)
3
Select <TCP/IP Settings>
![](./images/book_images/b_key_arrow_right.gif)
<Use HTTP>.
4
Select <Off>, and press
<Off>
Disables HTTP communication.
<On>
Enables HTTP communication.
5
Restart the machine.
Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
LINKS
