[IEEE 802.1X Settings].
Setting TLS|
1
Select the [Use TLS] check box and click [Key and Certificate...].
2
Click [Register Default Key] on the right of the key pair you want to use for the client authentication.
![]() NOTE:
Viewing details of a key pair or certificate You can check the details of the certificate or verify the certificate by clicking the corresponding text link under [Key Name], or the certificate icon. Verifying Key Pairs and Digital Certificates
Setting TTLS/PEAP|
1
Select the [Use TTLS] or [Use PEAP] check box.
![]() NOTE:
Internal protocol for TTLS You can select MSCHAPv2 or PAP. If you want to use PAP, click the [PAP] radio button. ![]() |
2
Click [Change User Name/Password].
To specify a user name other than the login name, clear the [Use Login Name as User Name] check box. Select the check box if you want to use the login name as the user name.
3
Set the user name/password and click [OK].
![]() [User Name]
Enter up to 24 alphanumeric characters for the user name. [Change Password]
To set or change the password, select the check box and enter up to 24 alphanumeric characters for the new password both in the [Password:] and [Confirm:] text boxes. |
You can enable or disable the IEEE 802.1X authentication from
. IEEE 802.1X Settings |
