Configuring FTP (imageRUNNER 1435iF / 1435i Only)
FTP (File Transfer Protocol) is a standard network protocol to transfer files over a network. You can send scanned documents to an FTP server. Communication methods of the FTP include active and passive mode. Passive mode is used when communicating with a firewall. For more information, contact your Network Administrator.
1
Start the Remote UI and log on in System Manager Mode.
Starting the Remote UI
2
Click [Settings/Registration].
3
Click [Network Settings]
![](./images/book_images/b_key_arrow_right.gif)
[TCP/IP Settings].
4
Click [Edit...] in [FTP PASV Mode Settings].
5
Specify the required settings and click [OK].
[Use FTP PASV Mode]
Select the check box to use passive mode. Clear the check box to use active mode.
6
Restart the machine.
Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
LINKS
