The machine's IPv4 address can be either assigned automatically by a dynamic IP addressing protocol, such as DHCP, or entered manually. When connecting the machine to a LAN, make sure that the connectors of the LAN cable are firmly inserted into the ports (Connecting to a LAN). You can test the network connection if necessary.
to select <Network Settings>, and press
. Logging on to the Machine
<IPv4 Settings>
<IP Address Settings>.
<Auto Acquire>
<Manually Acquire>
<Check Settings>
Automatically assigning an IP address|
1
Select <Auto Acquire>
<Select Protocol>.![]() |
2
Select <DHCP> and press
.![]() NOTE:
If you do not want to use DHCP to assign an IP address Select <Off>. When you select <DHCP> when the DHCP service is unavailable, the machine will search whether services are provided in the network and unnecessary communication will occur. |
3
Check that <Auto IP> is set to <On>.
If <Off> is selected, change the setting to <On>.
4
Press
Manually entering an IP address|
1
Check that <Auto Acquire> is set to <Off>.
![]() If <On> is displayed, select <Auto Acquire>
, and set both <Select Protocol> and <Auto IP> to <Off>. |
2
Select <Manually Acquire>, and press
3
Specify the IP address, subnet mask, and gateway address (or default gateway).
Specify the settings in the following order: <IP Address>
<Subnet Mask> <Gateway Address>.Enter the setting using the numeric keys, and press
on each screen.![]() |
Checking whether the settings are correct
Make sure that the Remote UI screen can be displayed with your computer (Starting the Remote UI). If a computer is not available, you can check the connection by using the operation panel (Testing the Network Connection).
<IPv4 Settings>
<PING Command>.
