System Requirements
LDAP servers that are supported by the machine are Windows Server 2003/Server 2008/Server 2012 Active Directory.
The machine communicates with LDAP servers using LDAPv3.
UTF-8 is the supported character encoding used when the text data is transmitted between the machine and an LDAP server.
Authorized Send is not available in an IPv6 environment.
[LDAP Server Settings].
click [OK].
[Use]
Select to authenticate the machine using the login information.
[Use (Security Authentication)]
Select to use data obtained by Kerberos, a network authentication protocol, for the authentication password. If this setting is selected, the clock of the machine needs to be synchronized with that of the LDAP server (Configuring SNTP).
[Authentication Settings for Send Function]
is pressed to log off, also select the [Display Confirmation Screen When Logging Out] check box.
Specifying settings for sending e-mail
[Do Not Allow]
Select to disable users from sending e-mails from the machine.
[Allow]
Select to enable users to send e-mails from the machine.
[Only Allow Sending to Myself]
Select to restrict the destination of documents being sent to the e-mail addresses of a logged-on users.
[Display the authentication screen using the same user name as when the sending operation started]
Select to have users confirm their user names and passwords on the authentication screen before e-mail transmissions. When the screen is displayed, the user name and password of the logged-on user are already entered in the corresponding text boxes.
[Display the authentication screen without any authentication information]
Select to require users to enter their user names and passwords on the authentication screen each time they send e-mails. A screen with blank text boxes is displayed before e-mail transmissions.
[Use device-specific authentication information and do not display the authentication screen]
Select to use the user name and password of the machine for SMTP authentication. The authentication screen for entering the user name and password is not displayed when e-mails are sent. Configuring the Machine for Scanning to E-mail
Specifying settings for sending files
[File Sending:]|
[Do Not Allow]
Select to disable users from sending files from the machine.
[Allow]
Select to enable users to send files from the machine.
[Only Allow Sending to Myself or Specified Folder]
Select to restrict the destination of documents to be sent to the folder of a logged-on user or to the folder specified in the [Specify Destination Folder] setting. The folder location of a logged-on user is defined by the LDAP home directory setting and depends on the [When Sending File to Myself] setting.
[When Sending File to Destination Registered in Address Book]|
[Display the authentication screen using the same authentication information as when the sending operation started]
Select to have users confirm their user names and passwords on the authentication screen before file transmissions. When the screen is displayed, the user name and password of the logged-on user are already entered in the corresponding text boxes.
Select to require users to enter their user names and passwords on the authentication screen each time they send files. A screen with blank text boxes is displayed before file transmissions.
[Use the authentication information from the address book and do not display the authentication screen]
Select to authenticate users by confirming the user name and password registered in the address book. If you select this setting, the authentication screen is not displayed.
[When Sending File to Myself]|
[Use the same authentication information as when the sending operation started]
Select to automatically authenticate users or have users confirm their user names and passwords on the authentication screen before file transmissions. If this option is selected, also set the [Display Authentication Screen] setting. When the authentication screen is displayed, the user name and password of the logged-on user are already entered in the corresponding text boxes.
Selecting fax sending
[Do Not Allow]
Select to disable users from sending faxes from the machine.
[Allow]
Select to enable users to send faxes from the machine.
You cannot disable PC faxing by specifying the setting here.
