All the settings about the printer are listed with short descriptions. Default settings are marked with a dagger (
Asterisks (*)
Settings marked with "*1" are only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PCL Printer Kit or PS Printer Kit enabled.
Settings marked with "*2" have different defaults depending on the country or region of purchase.
Settings marked with "*3" are only for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PCL Printer Kit and PS Printer Kit enabled.
Settings marked with "*4" are only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PCL Printer Kit enabled.
Settings marked with "*5" are only available when the optional Barcode Printing Kit is enabled.
Settings marked with "*6" are only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PS Printer Kit enabled.
Priority of settings
Settings that are specified in an application or on the printer driver will override those specified on the machine. The settings described in this section are especially useful if you are printing on an operating system such as UNIX on which the printer drivers for the machine are not available.
1
to 99 (Copies) |
This function is not available on the PCL5 printer driver.
<Printer Settings>
<Copies>
Set the number of copies to print
Off
![]() On |
<Printer Settings>
<2-Sided Printing>
Select <Off> or <On>
<Default Paper Size> and <Default Paper Type> cannot be specified separately. Specify the paper size in the <Default Paper Size> screen, and then specify the paper type in the <Default Paper Type> screen.
LTR
![]() LGL STMT EXEC FOOLSCAP
OFICIO
No. 10 (COM10)
Monarch DL ISO-C5
Government-LTR
Government-LGL
AUS-FOOLSCAP
Brazil-OFICIO
Mexico-OFICIO
A4
A5
B5
Plain (17 lb bond to 24 lb bond [64-90 g/m²])
![]() Recycled
Color Thin (16 lb bond [60-63 g/m²])
Heavy 1 (25 lb bond to 28 lb bond [91-105 g/m²])
Heavy 2 (29 lb bond to 34 lb bond [106-128 g/m²]) Transparency Labels Envelope
If you select an envelope (<No. 10 (COM10)>, <Monarch>, <DL>, or <ISO-C5>) as the paper size in <Default Paper Size>, only <Envelope> is available as a paper type.
<Printer Settings>
<Default Paper>
Select the paper size
Select the paper type
Off
![]() On |
<Printer Settings>
<Paper Size Override>
<Off>
<On>|
The settings specified for <Density> are disabled when <Toner Save> is enabled.
17 Levels
<Printer Settings>
<Print Quality>
<Density>
<Density>
Specify the density
<Apply>
High
17 Levels
Medium
17 Levels
Low
17 Levels
<Printer Settings>
<Print Quality>
<Density>
<Density (Fine Adjust)>
Select <High>, <Medium>, or <Low>
Specify the density
<Apply>
<Apply>
Off
![]() On |
When this setting is enabled, fine lines and portions with lighter print density may become blurred.
<Printer Settings>
<Print Quality>
<Toner Save>
Off
On
<Printer Settings>
<Print Quality>
<Image Refinement>
in the illustrations below represent margins.
Long Edge
![]() Short Edge
You cannot create a binding margin with this setting alone. Use this setting in combination with the <Gutter> setting to set the binding margin for the selected binding position.
<Printer Settings>
<Layout>
<Binding Location>
Select <Long Edge> or <Short Edge>
-1.90 to ±0
to +1.90 (inches) or -50.0 to ±0 to +50.0 (mm) |
If this setting moves any of the print data outside the printable area, the portion outside the printable area will not be printed.
<Printer Settings>
<Layout>
<Gutter>
Specify the binding margin
-2.00 to ±0
to +2.00 (inches) or -50.0 to ±0 to +50.0 (mm) |
You can specify this setting in combination with the <Offset Long Edge (Front)>, <Offset Short Edge (Back)>, and <Offset Long Edge (Back)>. By specifying all four settings, for example, the print position is shifted as shown in the illustration below.
![]() If the offset settings are specified in combination with the <Gutter> setting, the specified values are added together.
<Printer Settings>
<Layout>
<Offset Short Edge (Front)>
Specify the offset value
-2.00 to ±0
<Printer Settings>
<Layout>
-2.00 to ±0
<Printer Settings>
<Layout>
-2.00 to ±0
<Printer Settings>
<Layout>
Off
![]() On |
Error skip bypasses errors in print data, so the document may not be printed correctly.
You can manually perform error skip.
Press (Status Monitor) <Copy/Print Job> <Job Status> select the document containing errors <Skip Error> . |
<Printer Settings>
<Auto Error Skip>
5 to 15
to 300 (sec.) |
Provide the machine with enough time to receive all the print data from the computer, especially when printing large amounts of data. If you specify a time period that is too short, the machine may not receive all the print data in time for printing.
<Printer Settings>
<Timeout>
Set the time period
Auto
![]() PS
PCL
<Printer Settings>
<Personality>
Select <Auto>, <PS>, or <PCL>
Off
![]() On |
<Printer Settings>
<PCL>
<Paper Save>
Portrait
![]() Landscape
<Printer Settings>
<PCL>
<Orientation>
Select <Portrait> or <Landscape>
0
to 104 |
<Printer Settings>
<PCL>
<Font Number>
Select the font number
4.00 to 12.00
to 999.75 (point) |
<Printer Settings>
<PCL>
<Point Size>
Specify the point size
0.44 to 10.00
to 99.99 (cpi) |
<Printer Settings>
<PCL>
<Pitch>
Specify the pitch value
5 to 60
to 128 (lines) |
<Printer Settings>
<PCL>
<Form Lines>
Specify the number of lines
<Printer Settings>
<PCL>
<Character Code>
Select the character code
Off
![]() On |
<Printer Settings>
<PCL>
<Custom Paper>
Millimeters
Inches
<Printer Settings>
<PCL>
<Unit of Measure>
Select <Millimeters> or <Inches>
3 to 8 1/2
(inches) or 76 to 216 (mm) |
<Printer Settings>
<PCL>
<X dimension>
Specify the dimension
5 to 14
(inches) or 127 to 356 (mm) |
<Printer Settings>
<PCL>
<Y dimension>
Yes
No
<Printer Settings>
<PCL>
<Append CR to LF>
Select <Yes> or <No>
Off
![]() On |
<Printer Settings>
<PCL>
<Enlarge A4 Print Width>
Text
Resolution
![]() Color Tone
Gradation
High Resolution
Graphics
Resolution
Color Tone
![]() Gradation
High Resolution
Resolution
Color Tone
![]() Gradation
High Resolution
<Printer Settings>
<PCL>
<Halftones>
Specify the halftones settings
<Resolution>
<Color Tone>
<Gradation>
<High Resolution>
Disable
![]() Enable
<Printer Settings>
<PCL>
<BarDIMM>
Select <Enable> or <Disable>
Off
This setting is available only when <BarDIMM> is enabled.
<Printer Settings>
<PCL>
<FreeScape>
Select an escape code
0
to 3600 (sec.) |
<Printer Settings>
<PS>
<Job Timeout>
Set the time period
Off
![]() On
<Printer Settings>
<PS>
<Print PS Errors>
Text
Gradation
Resolution
![]() High Resolution
Graphics
Gradation
Resolution
Gradation
Resolution
<Printer Settings>
<PS>
<Halftones>
<Gradation>
<Resolution>
<High Resolution>|
sRGB
NTSC
![]() Uniform RGB
This setting is invalid for black-and-white data.
<Printer Settings>
<PS>
<Grayscale Conversion>
Select <sRGB>, <NTSC>, or <Uniform RGB>
<sRGB>
<NTSC>
<Uniform RGB>
