*1 Automatic 2-sided printing is available without replacing paper.
*2 The machine can print received fax documents (imageRUNNER 1435iF only).
*3 You can load in the multi-purpose tray.
*4 You can load in the paper drawer.
*5 Custom paper size of 3" to 8 1/2" (76 to 216 mm) in width and 5" to 14" (127 to 356 mm) in length can be loaded in the multi-purpose tray.
The default paper size of the machine is set to Letter. Change the paper size setting when using a different size of paper.
Paper Type
Paper Capacity for Paper Drawer
Paper Capacity for Multi-Purpose Tray
Plain paper*1
17 lb bond to 21 lb bond (64 to 80 g/m²)
500 Sheets
100 Sheets
22 lb bond to 24 lb bond (81 to 90 g/m²)
480 Sheets
90 Sheets
Heavy paper
25 lb bond to 28 lb bond (91 to 105 g/m²)
80 Sheets
29 lb bond to 34 lb bond (106 to 128 g/m²)
50 Sheets
Recycled paper*1
500 Sheets
100 Sheets
480 Sheets
90 Sheets
Color paper*1
500 Sheets
100 Sheets
480 Sheets
90 Sheets
Thin Paper
16 lb bond (60 to 63 g/m²)
110 Sheets
Transparency*2
10 Sheets
Label
40 Sheets
Envelope
10 Sheets
*2 Use laser printer transparencies.
