The Address Book enables you to specify a destination by selecting from a list of registered destinations or by searching by name for destinations with recipient names. You can also directly specify a destination by pressing a one-touch key or by entering a three-digit number (coded dial number) assigned to a destination.
You need to register destinations in the Address Book beforehand.
(Address Book).
to select <Specify from Address Book> on the screen, and press
to select a tab.
<All>
to select a destination, and press
to select <Specify Next Destination (New)> on the screen, and press
To delete destinations
1
Select <Confirm/Edit Destination>, and press
2
Select a destination you want to delete, and press
3
Select <Delete Destination>, and press
.If you specified a group destination in step 2, <Number of Destinations> is displayed on the screen. Selecting this item and pressing
displays the destinations in the group.![]() |
4
Select <Yes>, and press
If you want to easily and quickly delete destinations without displaying a list of destinations
Before selecting <Confirm/Edit Destination> in step 1, you can press
/ to toggle the destinations you specified. Display a destination you want to delete <Yes> . |
. To cancel the destination you have specified, select <Cancel>, press
, and press a one-touch key again. Displaying Destinations in Address Book
1
2
3
4
(Coded Dial).
to select <Specify from Coded Dial> on the screen, and press
. (Press to delete each character one by one. Press and hold to delete all the input characters at once.)
, and enter a three-digit number again. Displaying Destinations in Address Book
1
2
3
4
