The setup of the computer and wireless LAN router or access point must be completed.
![]() If it is not set up, you will not be able to use the machine on the wired LAN network.
For the details, refer to the instruction manual for your network device or contact its manufacturer. |
Precautions when connecting to a wireless LAN
The structure of your computer or networked device, the existence of router functions, setting methods and security settings vary depending on your environment.
You can connect the machine to wireless LANs or wired LANs, but you cannot use both at the same time. When using a wireless LAN connection, do not connect a LAN cable to the machine. This may cause malfunctions.
If using the machine in your office, consult with your network administrator.
] (Menu).
] or [
], and then press [OK].
] or [
] or [
Checking WPS functions
Check whether the box or body of the wireless LAN router or access points that you are using supports the WPS function.
As an example, a symbol such as shown below can be seen on the shipping box or machine.
![]() This supports WPS (Wi-Fi Protected Setup).
If you are not sure if WPS is supported, contact the wireless LAN router or access point manufacturer.
] (Menu).
] or [
] or [
] or [
] to select <Yes>, and press [OK].
The amount of time you must hold down the WPS button will depend on the model you are using.
Please refer to the instruction manual for your wireless LAN routers and/or access points. |
If "Cannot find Access Point" appears, press [OK] to close the screen, and follow the procedure from Step 6.
If an error message appears, press [OK] to close the screen, and repeat starting from Step 6.
If you cannot detect the access point after retrying, see the following:
For more information on how to check, refer to the instruction manual of the wireless LAN router or access point, or contact the manufacturer.
It may be indicated as access point name or network name.
It may be indicated as encryption key, WEP key, WPA/WPA2 passphrase, PSK or pre-shared key.
Checking for SSID and network keys
There are cases when the defaults are written on the body of the wireless LAN router or access point. If the settings for the wireless LAN router or access point have changed or are not written, or if you are not sure of the settings, see the following.
] (Menu).
] or [
] or [
] or [
] or [
See the following when the <Cannot find access point.> is displayed.
] or [
See the following when you cannot find an access point you want to connect.
] or [
(1)
Press [
] (Tone), and then select <Entry Mode>. |
(2)
Enter the network key.
You can enter it using the numeric keys. |
(3)
Select <Apply> using [
] or [ ], and then press [OK]. |
(1)
Select the character using [ ] or [ ], and then press [OK] to enter. |
(2)
] and press [OK].
If an error message appears, press [OK] to close the screen, check to make sure that the network key is correct, and follow the procedure in 7 again.
If you cannot connect the access point after retrying, see the following:
