e-ManualTopSite mapHelp
Top » Maintenance » Cleaning and Maintaining the Printer » Cleaning the Outside of the Printer
07E3-01W
Before cleaning, see "Attention (Cleaning)."
1
Turn the printer OFF, and then disconnect the cables or cords from the printer.
Shut down the printer before turning it OFF.
For details on the procedure for shutting down the printer, see "Turning the Printer ON/OFF."
<How to disconnect the cable or cord>
USB cable*
(2) Turn the computer OFF.
(3) Disconnect the cable from the printer.
LAN cable*
(4) Disconnect the cable from the printer.
Power cord
(5) Disconnect the power plug from the AC power outlet.
(6) Disconnect the cord from the printer.
Whether the cable is connected or not varies depending on your environment.
2
Firmly wring a soft cloth dampened with water or a mild detergent diluted with water, and wipe off the dirt.
3
After wiping off the dirt, wipe the printer with a dry cloth.
4
When the printer is completely dry, connect the removed cable or cord.
<How to connect the cable or cord>
USB cable*
Connect to the USB connector on the printer.
LAN cable*
Connect to the LAN connector on the printer.
Power cord
(1) Plug the power cord to the power socket on the printer.
(2) Plug the power plug in the AC power outlet.
