Before replacing toner cartridges, see "Attention (Toner Cartridge)."
Keep the protective bag. Do not discard it. You will need it when you remove the toner cartridge for printer maintenance or other purposes.
Keep the removed drum protective cover. You will need it when you remove the toner cartridge for printer maintenance or other purposes.
Precautions when installing toner cartridges
The position of the toner cartridges in the printer is determined by the toner color. Install the toner cartridges in the slots that have labels of the same color.
If you cannot close the front coverMake sure that the toner cartridges are installed in the printer properly. Do not try to forcefully close the front cover, as this may damage the printer.
