When adjusting the toner density
Adjusting the toner density little by little, print the defective print data from the computer, and then check the printout results. If you cannot adjust the toner density, reset the density to the default value "0", and then contact your local authorized Canon dealer.
When [Toner Save] is enabled
This setting is unselectable. Disable [Toner Save], and then perform the following procedure.
Settings).
] and [
], and then press [OK].
] and [
] and [
] and [
The density is set.
[High]
[Mid]
[Low]
