For details on the yield of the toner cartridge or replacement toner cartridges, see "Consumables."
Toner cartridges are consumable products. When the toner cartridge is nearing the end of its life, the following symptoms occur.
<16 Tnr cart. will soon reach end of lifetime.>, <Toner cartridge will soon reach end of lifetime.>, <9F Check the toner cartridge.> or <1G Change toner cartridge recommended.> appears in the Control Panel.
![]() For details on the contents of and the solutions for the above messages, see "If a Message Appears in the Display."
White streaks, unevenness, or faded print appears on printout results.
If these types of symptom occur
Perform the procedure described in the following section before replacing the toner cartridge. You may be able to print for a while until the toner is used up completely.
If the printout result is not improved
If white streaks, unevenness, or faded print appears on printout results even after performing the above procedure, replace the toner cartridge with a new one.
Message
When it is Displayed
Contents and Solutions
When the toner cartridge needs to be replaced soon
You can continue to print.
Have ready a new toner cartridge.
We recommend that you replace the toner cartridge before printing a large amount of data.
The printer stops printing.
Pressing [
] ( Online) continues the job.Have ready a new toner cartridge.
The toner cartridge may have reached the end of its life.
As continuing to print may result in damage to the printer, we recommend that you replace the toner cartridge with a new one.
The toner cartridge has reached the end of its life.
Replace the toner cartridge with a new one.
<1H Re-insert the toner cartridge.>
When the toner cartridge is not installed in the proper position
Remove the toner cartridge, and then reinstall it properly.
Whether <16 Tnr cart. will soon reach end of lifetime.> or <Toner cartridge will soon reach end of lifetime.> appears when the toner is running out depends on the setting for [Warning Step] in the [Setup] menu. The printer is set to display <16 Tnr cart. will soon reach end of lifetime.> in the default settings. For details on the setting for [Warning Step], see "[Setup] Menu ([Control Menu] Options)."
