Name
Status
Refer to
(1) Ready Indicator
![]() (On)
The printer is ready to print.
![]() (Blinking)
The printer is preparing to print.
(5) Online Indicator
![]() (On)
Online (The printer can receive print data from the computer.)
If the printer enters Sleep Mode, the ![]() |
(6) Message Indicator
![]() (On)
A problem has occurred and printing cannot be performed.
(If the printer enters Sleep Mode when it is offline, the ![]() |
(7) Job Indicator
![]() (On)
The printer is receiving data.
Data remains in the printer memory. |
![]() (Blinking)
The printer is processing data.
(8) Main Power Indicator
![]() (On)
The power of the printer is ON.
(16) Paper Source Indicators
![]() (On)
A paper source is selected.
![]() (Blinking)
Printing cannot be performed because no paper is loaded.
The paper drawer is not installed. (For the multi-purpose tray, the indicator comes on even when no paper is loaded.) |
Name
Function
(When the printer is online)
Function
(When the printer is offline)
Function
(While the menu is displayed)
(2)
![]() (Job Status/Cancel)
If pressed when the
![]() This key is indicated as [
Does not function.
(3)
Displays the [Utility Menu] menu. Prints information about the printer settings including the current settings. This key is indicated as [
Does not function.
Goes back up the previous hierarchy. This key is indicated as [
(4)
Does not function.
(5)
Switches between online and offline. The printer is online when the indicator under the key is on and is offline when the indicator is off.
This key is indicated as [ ![]() ![]() |
(9)
![]() (Energy Saver)
If [Sleep Mode] is set to a setting other than [Off], the printer enters Sleep Mode.
This key is indicated as [ ![]() |
(10)
Displays the [Job] menu. You can print various log lists. This key is indicated as [
Does not function.
Selects the next upper item in the same hierarchy. When the setting value is numeric, increases the value. If you keep holding down the key, the speed of the value increasing is increased depending on the item. This key is indicated as [
(11)
Displays the [Setup] menu. Configure the printing environment including the layout adjustment and scaling print output. This key is indicated as [
Goes down the hierarchy. This key is indicated as [
(12)
![]() (OK)
Does not function.
Executes the selected item. Otherwise, goes down the hierarchy. This key is indicated as [OK] in this manual.
(13)
Displays the [Reset] menu. Performs the printer reset operation, the print data output, and the shutdown operation. This key is indicated as [
Selects the next lower item in the same hierarchy. When the setting value is numeric, reduces the value. If you keep holding down the key, the speed of the value decreasing is increased depending on the item. This key is indicated as [
(14)
The log in screen for using MEAP functions is displayed.
(15)
It will transition to the Menu Screen. Whenever the key is pressed, the Printing Screen switches to → MEAP Application 1 → MEAP Application 2 … MEAP Application 8 → USB Direct Print → Printing Screen → Menu Screen.
(17)
Displays the [Select Feeder] menu. Specify which paper source is used to print between the paper drawer and multi-purpose tray and the paper size.
Does not function.
When the printer is ready to print
When operating the printer using the control panel
(1)
Status/Operation Field
Displays the printer status and print mode.
(2)
Paper Source/Paper Size Field
Displays the size of paper in the currently selected paper source using an abbreviation.
The names of the following paper sizes are indicated by an abbreviation. (Legal: LG, Letter: LT, Executive: EX, Statement: ST, Foolscap: FC, 16K: 16K, Envelope DL: DL, Envelope No.10: CO, Envelope ISO-C5: EC5, Envelope Monarch: MO, Index Card: IC, Custom Size: 80 to 99, Custom SizeR: 80R to 99R, Mixed Sizes: FR) |
(3)
Toner Remaining Field
Displays the amount of toner remaining.
