Cleaning the Fixing Roller of the Printer
If the printed paper has smudge marks, clean the fixing roller using the following procedure.
A4 or Letter plain paper is required to clean the fixing roller. Have A4 or Letter plain paper ready.
1
Load Letter size plain paper in the multi-purpose tray.
2
Make sure that the printer is online.
If the printer is not online, press [  ] (Online).
3
Press [  ] (Utility).
4
Select [Cleaning] using [ ] and [ ], and then press [OK].
5
Select the size of the paper loaded in the multi-purpose tray using [ ] and [ ], and then press [OK].
6
Select [Yes] using [ ], and then press [OK].
<Insert paper to be used for cleaning.> is displayed on the display.
7
Press [  ] (Online).
The cleaning paper is printed.
<Set cleaning paper and press the Online key.> is displayed on the display.
Next, clean the fixing roller using the printed cleaning page.
8
If any paper is loaded in the multi-purpose tray, remove it.
9
Load the cleaning paper with the printed side facing up and the arrow mark going into the multi-purpose tray first.
10
Press [ ] (Online).
The paper is fed into the printer slowly, and the printer starts cleaning the fixing roller.
Cleaning time
It takes approximately 80 seconds.
Cleaning the fixing roller cannot be canceled. Please wait until it is completed.
(The cleaning is finished when the paper is output completely.)
The front or back of the printed paper has smudge marks even after performing the above procedure.
Perform the cleaning again. When doing so, do not use the cleaning paper output but load A4/Letter blank paper in the multi-purpose tray, and then perform the cleaning.
» Maintenance » Cleaning and Maintaining the Printer » Cleaning the Inside of the Printer » Cleaning the Fixing Roller of the Printer
08X4-01U
