e-ManualTopSite mapHelp
Chapter Top
Checking Your Network Environment
Example of a Windows Network
Example of a Macintosh Network
Example of a UNIX Network
Example of a Network Using a Variety of Computers
Network Settings for the Printer (Common to Each Protocol)
Changing the Network Transmission Speed or Transfer Mode
Performing the Configuration Using the Printer's Control Panel (When You First Set it Up)
Changing the Settings Using Web Browser (Remote UI)
Setting the Spooling Function
Performing the Configuration Using the Printer's Control Panel (the Settings to Be Performed First)
Specifying the Setting for Startup Waiting Time
Restricting the Users Who Can Monitor/Change the Settings Using the SNMP Protocol
Setting IEEE802.1X Authentication
Setting TLS Authentication Information
Setting TTLS/PEAP Authentication Information
Network Setting Items
Initializing the Network Settings
Initializing the Network Settings Using the Printer's Control Panel
Checking the MAC Address
Network Settings for the Printer (TCP/IP)
Setting the IP Address (IP v. 4)
Setting the IP Address Using the Printer's Control Panel
Setting the Printer to a Static IP Address
Determining Which IP Address to Assign to the Printer
Setting the IP Address Using the ARP/PING Commands
Setting the IP Address Using NetSpot Device Installer
Configuring the Protocol Settings
Attention (Protocol Settings)
Setting IP v. 6
Configuring a Computer that Performs Printing
Features of LPD
Features of RAW
Features of IPP/IPPS
Features of WSD
Connecting the Printer (LPD/RAW)
Values for Setting a Port
Connecting the Printer (IPP/IPPS)
Obtaining the Public Key for This Printer When Using SSL Encrypted Communication
Connecting the Printer (WSD)
Network Settings for the Printer (NetWare)
Attention (NetWare Network Settings)
Configuring NetWare
Network Settings for the Printer (SMB)
Attention (SMB Network Settings)
Network Settings for the Printer (AppleTalk)
Macintosh Network Settings
FTP Client (Macintosh)
Top » Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (TCP/IP) » Setting the IP Address (IP v. 4)
08X4-087
There are the following three methods for setting the IP address.
Set the IP address using the control panel while checking the display on the printer.
Set the IP address using the ARP/PING command in Command Prompt.
Set the IP address using NetSpot Device Installer in the supplied CD-ROM.
When setting the IP Address using the ARP/PING command or NetSpot Device Installer
The MAC address of the printer is required. For details on the procedure for checking the MAC address, see "Checking the MAC Address."
Before setting the IP address
Make sure that the printer is connected to the network and the printer is ON.
If you changed the IP address after installing the printer driver
Specify the port to be used again in the printer driver.
