e-ManualTopSite mapHelp
Chapter Top
Checking Your Network Environment
Example of a Windows Network
Example of a Macintosh Network
Example of a UNIX Network
Example of a Network Using a Variety of Computers
Network Settings for the Printer (Common to Each Protocol)
Changing the Network Transmission Speed or Transfer Mode
Performing the Configuration Using the Printer's Control Panel (When You First Set it Up)
Changing the Settings Using Web Browser (Remote UI)
Setting the Spooling Function
Performing the Configuration Using the Printer's Control Panel (the Settings to Be Performed First)
Specifying the Setting for Startup Waiting Time
Restricting the Users Who Can Monitor/Change the Settings Using the SNMP Protocol
Setting IEEE802.1X Authentication
Setting TLS Authentication Information
Setting TTLS/PEAP Authentication Information
Network Setting Items
Initializing the Network Settings
Initializing the Network Settings Using the Printer's Control Panel
Checking the MAC Address
Network Settings for the Printer (TCP/IP)
Setting the IP Address (IP v. 4)
Setting the IP Address Using the Printer's Control Panel
Setting the Printer to a Static IP Address
Determining Which IP Address to Assign to the Printer
Setting the IP Address Using the ARP/PING Commands
Setting the IP Address Using NetSpot Device Installer
Configuring the Protocol Settings
Attention (Protocol Settings)
Setting IP v. 6
Configuring a Computer that Performs Printing
Features of LPD
Features of RAW
Features of IPP/IPPS
Features of WSD
Connecting the Printer (LPD/RAW)
Values for Setting a Port
Connecting the Printer (IPP/IPPS)
Obtaining the Public Key for This Printer When Using SSL Encrypted Communication
Connecting the Printer (WSD)
Network Settings for the Printer (NetWare)
Attention (NetWare Network Settings)
Configuring NetWare
Network Settings for the Printer (SMB)
Attention (SMB Network Settings)
Network Settings for the Printer (AppleTalk)
Macintosh Network Settings
FTP Client (Macintosh)
Top » Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (TCP/IP) » Configuring the Protocol Settings » Attention (Protocol Settings)
08X4-08H
When setting the IP address
If you changed the IP address after installing the printer driver
Specify the port to be used again in the printer driver.
When using DHCP, BOOTP, or RARP
One of the following can be used: DHCP, BOOTP, or RARP. When any of the settings is turned [On], the remaining two settings are automatically turned [Off].
Because it takes one to two minutes to check whether DHCP, BOOTP, and RARP are available, we recommend that you set the unused protocol(s) to [Off].
Each server or daemon (the DHCP server, BOOTP daemon, or RARP daemon) must be running on the network.
Even if you are using DHCP, BOOTP, or RARP, specify the settings for [IP Address], [Subnet Mask], and [Gateway Address] manually. If you cannot obtain information from the servers of DHCP, BOOTP, and RARP, the values specified manually are used.
After the printer restarts, the values obtained from DHCP, BOOTP, and RARP are displayed.
(If the values have been specified previously, they overwrite the obtained ones.)
When using DHCP
If you cycle the power of the printer, you may not be able to print. This is because a different IP address from the one that has been used is assigned.
When using DHCP, consult your network administrator and perform either of the following settings.
Specifying the DNS Dynamic Update function
Specifying the settings so that the same IP address is always assigned when the printer starts up
When configuring the DNS Settings
DNS Dynamic Update
DNS Dynamic Update is a function that adds the IP address of the device and the names specified as the host name and domain name to the DNS server automatically.
This function can be used in the environment in which a Dynamic DNS server is being used.
When using the DNS Dynamic Update function
You need to set the IP address, host name, and domain name of the DNS server.
When configuring the WINS Settings
WINS
WINS (Windows Internet Name Service) is a service that maps NetBIOS names (names of computers or printers) to IP addresses. A WINS server is required to use WINS.
If [Scope ID] is specified
The printer cannot communicate with the computers that have a different scope ID.
When configuring the Multicast Discovery Settings
Multicast discovery
This is a function that searches for certain devices using Service Location Protocol (SLP).
By using the multicast discovery function, you can search for only the devices whose values in [Scope Name] are verified, using the service location protocol (SLP) from utility software, such as NetSpot Device Installer.
When configuring the SNTP Settings
When the check box for [Use SNTP] is selected
[Check NTP Server Connection] is displayed on the [TCP/IP Settings] page on the [Network]. When [Check NTP Server Connection] is clicked, the printer communicates with the specified NTP server, and the result of the communication is displayed in [NTP Server Connection Check Result].
[OK] is displayed if the printer communicated with the NTP server successfully, and [Error] is displayed if the printer could not communicate with the NTP server due to any reason such as a setting mistake or communication error.
