Paper drawer
Width 4.13 to 8.50 in. (105.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)*1
Multi-purpose tray
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)*2
*1
If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long also in landscape orientation.
*2
If you are using the UFR II printer driver, you can load custom size paper that is 5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 5.00 to 8.50 in. (127.0 to 215.9 mm) long also in landscape orientation.
Paper Type
Paper Drawer
Multi-purpose Tray
Plain paper (16.0 to 19.8 lb Bond (60 to 74 g/m²))
Plain paper (19.9 to 23.9 lb Bond (75 to 90 g/m²))
Heavy paper (24.0 to 27.9 lb Bond (91 to 105 g/m²))
Heavy paper (28.0 lb Bond to 73.6 lb Cover (106 to 199 g/m²))
*1
You can use heavy paper of up to 44.4 lb Cover (120 g/m²).
The print speed drops when printing on heavy paper (24.0 lb Bond to 73.6 lb Cover (91 to 199 g/m²)).
