Paper Drawer *1
Multi-purpose Tray
Standard sizes
A4*2, B5, A5, A6, Legal*2, Letter*2, Executive, Statement, Foolscap*2, and 16K
A4*2, B5, A5, A6, Legal*2, Letter*2, Executive, Statement, Foolscap*2, 16K, and Index Card
Custom paper sizes*3
Width 4.13 to 8.50 in. (105.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)*4
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)*5
*1
You can use heavy paper of up to 44.4 lb Cover (120 g/m²).
*2
Can be used for 2-sided printing. (Heavy paper of 44.5 to 73.6 lb Cover (121 to 199 g/m²) cannot be used for 2-sided printing.)
*3
Custom size paper that is 8.27 to 8.50 in. (210.0 to 215.9 mm) wide and 11.00 to 14.00 in. (279.4 to 355.6 mm) long can be used for 2-sided printing. (Heavy paper of 44.5 to 73.6 lb Cover (121 to 199 g/m²)) cannot be used for 2-sided printing.)
*4
If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long also in landscape orientation.
*5
If you are using the UFR II printer driver, you can load custom size paper that is 5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 5.00 to 8.50 in. (127.0 to 215.9 mm) long also in landscape orientation.
Recycled paper can also be used.
: Available
: Unavailable|
Paper Type
Paper Drawer
Multi-purpose Tray
Plain paper (16.0 to 19.8 lb Bond (60 to 74 g/m²))
Plain paper (19.9 to 23.9 lb Bond (75 to 90 g/m²))
Heavy paper (24.0 to 27.9 lb Bond (91 to 105 g/m²))
Heavy paper (28.0 lb Bond to 73.6 lb Cover (106 to 199 g/m²))
*1 |
Index Card
*1
The following Index Card size is supported.
3.00 x 5.00 in. (76.2 x 127.0 mm)
The print speed drops when printing on heavy paper (24.0 lb Bond to 73.6 lb Cover (91 to 199 g/m²)).
