e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Limited Color PDF
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Setting the File Format
0S9Y-0JH
You can set the file format to use when scanning originals.
Press (Main Menu) → [Scan and Send] → specify the destination → press the file format button.
Select a file format for the image to send.
[JPEG]:
Sends the file in the JPEG format if you select a color mode other than Black-and-White.
[TIFF]:
Sends the file in the TIFF format only if you select Black-and-White.
[PDF]:
Sends the file in the PDF file format, regardless of the color mode. You can also specify additional settings.
[XPS]:
Sends the file in the XPS file format, regardless of the color mode. You can also specify additional settings.
[OOXML]:
Sends the file in the Office Open XML (pptx, docx) format only if you select the Full Color mode or the Grayscale mode for the color mode.
If you send the file stored in the Mail Box or Memory RX Inbox, you cannot select OOXML as the file format.
If you select [JPEG]:
If you select [TIFF], [PDF], [XPS], or [OOXML]:
Press [OK].
If you select [JPEG], [Divide into Pages] is set to 'On'.
Specify whether or not to divide your files into separate pages → press [OK].
If you want to separate multiple images and save them as separate files, set [Divide into Pages] to 'On'. If you want to store the images as a single file, set the setting to 'Off'.
You can select additional settings if you send in the PDF, XPS or OOXML format. Refer to the following for instructions on setting each type of PDF, XPS, or OOXML:
[Trace & Smooth]: Trace and Smooth
[Limited Color]: Limited Color PDF
[OCR (Text Searchable)]: Searchable PDF/XPS/OOXML
[Apply Policy]: Applying a Policy
