e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Limited Color PDF
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations
0L3X-112
You can specify a destination by selecting from the address book and the one-touch button, or entering a new address.
You can also recall destinations and sending settings from [Previous Settings] and [Favorite Settings] or specify destinations stored in the Job Log screen.
If the Destination Is Stored in the Address Book
If You Want to Enter a New Destination
Specifying Destinations with Useful Functions
Setting Cc and Bcc and Checking/Changing/Deleting Destinations
If you specify and send to an address not stored in the Local Address Book, it is not automatically added to the Address Book. It is deleted once the document is sent.
To view the detailed information for a selected destination, select the destination → press [Details].
You can change, edit, or delete destinations on the Fax Basic Features screen before scanning. (See "Checking/Editing/Deleting the Information for a Destination.")
You can specify a maximum of 256 destinations at the same time. However, if a group address is specified for the destination, each address stored in that group is counted as one destination.
If you frequently send documents to the same destinations, store these destinations in the Local Address Book beforehand. (See "Storing New Addresses.")
For instructions on specifying a fax number, see "Storing New Addresses."
