e-ManualTopSite mapHelp
Top » Status Monitor/Cancel » Using Destination of Send Jobs
0L3X-1ER
Destination which is already used for Send/Send (Fax) jobs can be selected from the job log. This mode is useful when you specify the used destination for a new send job, or register the destination to the address list and one-touch button.
Press (Status Monitor/Cancel).
Press [Job] → [Job Log] → select [Send] or [Send (Fax)] from the drop-down list.
Select a job you want to use the destination → select the desired operation.
You can select the following operations.
[Specify as Send Dest.]:
Displays a screen in which the address of the selected job is entered. Check the address → press [OK] to display the Send screen.
[Register Destinations]:
Registers the selected job as the destination. Select [Address Book] or [One-Touch] to display the Settings/Registration screen. (See "Register Destinations" or "Registering One-Touch Buttons.") If [Address Book PIN] is set in [Set Destination] (Settings/Registration), a screen appears prompting you to enter the password. (See "Setting the Address Book.")
4.
Press [Close].
