e-ManualTopSite mapHelp
Top » Hold » Page Numbering
Page Numbering
0L3X-195
This mode enables you to print page numbers, numbers with hyphens, and chapter numbers etc. on outputs.
This mode cannot be used with jobs without a job ticket.
Press (Main Menu) → [Hold].
Select the desired job → press [Details/Edit] → [Edit/Confirm Job Ticket].
Press [Edit] under <Overall Settings>.
4.
Press [Page Numbering].
5.
Select the type of page number.
6.
Set the image orientation and print position.
Orientation:
[Upright Image]:
Prints the image upright on the paper.
[Sideways Image]:
Prints the image sideways on the paper.
Upright Image
Sideways Image
You can press [Set Details] to set the printing position for the back side when performing two-sided printing.
Select [Opposite to Front Side] or [Same as Front Side] → press [OK].
7.
Specify the print settings for the page numbers.
Press the <Color> drop-down list → select the color of the page numbers.
Press the <Size> drop-down list → select the size of the page numbers.
Enter the starting number using - (numeric keys).
8.
To specify detailed printing settings, press [Set Details].
If you do not want to specify other settings, proceed to step 9.
Specifying the number of digits to be printed:
Counting inserted sheets:
Press [No. of Digits].
Press [-] or [+] to enter the number of digits to display → press [OK] → [OK].
You can specify between '2' and '5' digits.
Example:
If the page number is 10, and the number of digits is 2: 10 → 10
If the page number is 10, and the number of digits is 5: 10 → 00010
If the specified number of digits is less than the number of digits of the actual page number, the setting is invalid.
Press [Inserted Sheets].
Press [Count] → [OK] → [OK].
Counts all sheet insertions and back covers inserted after the first page. However, chapter numbers and page numbers are only printed onto the main document pages.
If you press [Do Not Count], the machine does not count any sheets or back covers inserted after the first page. Chapter numbers and page numbers are only printed onto the main document pages.
9.
Press [OK].
Printing performance may not be optimal, depending on the file content and combination of settings.
If you use [Page Numbering] with [Add Cover] or [Insert Sheets], numbers will not be printed on the inserted pages.
The Superimpose Image mode cannot be used with files including images with resolutions of less than 600 x 600 dpi.
If you select [With Chapter Numbers] in combination with the Sheet Insertion mode, the chapter numbers are counted at the following times:
After each sheet insertion is inserted.
